4 Replies Latest reply on Nov 10, 2016 7:16 PM by chrisdm
    Syncronizing "Auto" transforms "Update" button, help!
    chrisdm Level 1
      I have read all the FAQ's and discussions on this topic, but still cannot get this to work. I want LR to be able to apply the "Auto" transform to a set of real estate interior photos.
      I understand how to do this I believe, which is to simply apply the Auto Transform to the first image, then select the rest of the interior images, then  "Sync..." ->Transform -> Upright Mode.
      It should be that simple, and as described in the FAQ it is.. However the problem is this: I go to the next (and every) image in the series I had selected for the sync, and I see that "Auto" transform is selected (but not applied), but now this "Update" button is active and I have to click it to get LR to analyze that particular image and apply the Auto Transform. And I have to do this for every single image. I have to force LR to analyze each individual image and apply the Auto Transform with this Update button that I had seemingly successfully synchronized. Not a big deal for a few images, but I just shot a dozen model homes and have over 400 images I have to click next, Update, click, next, update, click, next, update, click, 400 times?... So how do I not only synchronize the Auto Transform to a batch of images but APPLY the Auto Transform to a batch of images?
      Thanks for your help!
      Chris Miller
      www.imagineimagery.com
        • 1. Re: Syncronizing "Auto" transforms "Update" button, help!
          johnrellis Most Valuable Participant
          Troubleshooting steps:
          1. Make sure that in the Synchronize Settings window, you've selected Upright Mode only:
          When you select Upright Transforms or Transform Adjustments as well, LR will activate the Update button.
          2. If 1 doesn't help, please report your exact version of LR (do Help > System Info).
          • 2. Re: Syncronizing "Auto" transforms "Update" button, help!
            chrisdm Level 1
            Thanks for the attempted assist John, but it turns out the current version of LR will not batch analyze Auto Transform as I was hoping it would. In fact this is why the "Update" button exists. It appears when Sync->Transform->Upright Mode only is checked, because LR will not analyze every image included in the sync. You must manually "Update" the Auto Transform for each image you have synchronized with the setting.
            I spent a couple hours on the phone and in Remote Desktop sessions with Adobe techs this morning until finally a tier 3 tech came in to let us know that what I was attempting to do is not possible.  This is a big disappointment and a huge PITA now that I have a couple thousand images in my workflow that I have to manually "auto" transform one at a time. I'm sure (praying) future versions of LR address this oversight.
            Thanks again for trying to help,
            Chris Miller
            • 3. Re: Syncronizing "Auto" transforms "Update" button, help!
              Adobe support is mistaken (a not infrequent occurrence).
              Here is a video showing LR CC 2015.7 properly syncing Upright Mode > Auto on 9 photos: https://dl.dropboxusercontent.com/u/21811200/sync-transform-auto.2016.11.10.mov.
              I tried 100 photos and then 400 photos, in two different catalogs, a long-abused test catalog and a fresh catalog. I was able to reproduce your symptoms in the old test catalog -- I saw the Update button enabled on some of the photos after syncing.  However, I then selected all the photos and did Library > Previews > Build Standard-Sized Previews.  After the preview build completed, all of the thumbnails showed that Auto had been applied, and the Update button was no longer active.   And after a couple iterations of this, the symptoms stopped occurring altogether.
              I think this bug is a variant of a problem that LR has long had with large-scale batch operations.  It tries to defer the recomputation of the thumbnails until they are actually visible in the Library grid, but sometimes it gets it wrong. For example, see this bug: Lightroom: Applying Auto Tone to a batch of photos loses subsequent develop settings | Photoshop Family Customer Communi… The workaround for that bug is the same -- invoke Build Standard-Sized Previews.
              • 4. Re: Syncronizing "Auto" transforms "Update" button, help!
                chrisdm Level 1
                That's awesome man, I hope you're right. I have a couple thousand photos to test this out on tomorrow, will report back.
