3 Replies Latest reply on Nov 11, 2016 11:40 AM by Wosven
    Use getFiles() in an array
    jakec42735283
      Hi all,
      I'm trying to write a script which searches a folder for packaged files and then searches the links of those files.
      I want to store the links and their files separate arrays.
      When I put the packaged files in an array I cant seem to use the getFiles() function.
      var links = [],
      packaged = [],
      files = [],
      myFolder = Folder( "A:\jake/" ),
      myDocs = [],
      myFiles = myFolder.getFiles(),  //store the target files in a variable
      i;
      for ( i = 0; i < myFiles.length; i++ ) {
           if (myFiles[i] instanceof Folder ) {
          var links = myFiles[i].getFiles( "Links" )
          packaged.push( links );
      this is a snippet. The packaged array contains all the links folders but when I try and loop through them
      for ( i = 0; i < packaged.length; i++ ) {
          var y = packaged[i].getFiles()
          links.push( y );
      This doesn't work.
      Any ideas?
        • 1. Re: Use getFiles() in an array
          Jump_Over Level 5
          "Links" is not an extension (to filter) but a name of folder (a part of path), so:
          var links = Folder(myFiles[i] + "/Links/").getFiles();
          jarek
          • 2. Re: Use getFiles() in an array
            jakec42735283 Level 1
            I'm using this:
            var links = [],
            packaged = [],
            files = [],
            myDocs = [],
            i;
                 if ( myFiles[i] instanceof Folder ) {
                packaged.push( Folder(myFiles[i] + "/Links/").getFiles() );
                $.writeln( packaged[i] );
            But it doesn't seem to pick up all the files (only the first three folders get checked)
            • 3. Re: Use getFiles() in an array
              Wosven Level 1
              Hello,
              Perhaps it' s a problem with file or folder's names.
              Your script works fine, but I get empty packaged array when there's no "Links" folder, so iI added : " && Folder(myFiles[i] + "/Links/").exists"
              var links = [],
                  packaged = [],
                  files = [],
                  myDocs = [],
                  myFiles = myFolder.getFiles();  //store the target files in a variable
              for (var i = 0; i < myFiles.length; i++ ) {
                  if ( myFiles[i] instanceof Folder && Folder(myFiles[i] + "/Links/").exists) {
              for (var i = 0; i < packaged.length; i++ ) {
                  //alert( packaged[i] );
