• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Problems converting a PDF file from the USA 'letter' size to the RSA 'A4' size (and converting to A5)
New Here ,
Nov 11, 2016 Nov 11, 2016
I am experiencing problems when trying to convert a PDF file from the USA page size (letter) to RSA page size (A4) (and converting to A5).   I go through the required steps of going to my print page and selecting the "Adobe PDF Converter" printer.  Thereafter I select the "Properties" button. My Default Settings shows "standard" and the Adobe PDF Page Size shows "A4" instead of "Letter" (with the A5 sizing it shows as A4).
In effect my Adobe is reading the USA letter size (215.9 x 279.4mm) as "A4" instead of as "Letter".  I have even tried to create my own A4 standard size (210 x 297mm), but this has no impact whatsoever, as when I then select the A4 and then select "Print", I am left with a new file that has exactly the same page size as the original PDF file.  It is as if my Adobe has the same page size set for "letter" and "A4", but myself and my IT specialist have no idea why this is happening.  We have tried several things to change this, but to no avail.  We have created correct A4 sizing under a different name, deleted and re-installed the Adobe PDF Converter and still no change.
I am experiencing exactly the same scenario with the A5 sizing, where the USA PDF is seen as A4 and when I select A5 it does not change and I am again left with a final document with various page sizes.
I add a few standard pages to the PDF document and then I am left with a file with different page sizes, which I cannot send to my Printers. Has anyone experienced this and how can it be solved?  It is the strangest thing really.....
Can someone help me please as I need urgent help in finding a resolution
Many thanks
Charmaine
TOPICS
Edit and convert PDFs
Views
323
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert ,
Moved out of the Forum Lounge (a non-tech support area) and to the Editing & Exporting PDFs forum.
Votes
Translate
Translate
Report
Report
Community Expert ,
LATEST
Which version of Acrobat are you using, on what operating system?
In genreal, it's a bad idea to print a PDF file to the "Adobe PDF" printer. This will always create a lower quality PDF file than what you started with. To change page sizes in Acrobat DC Pro, you can use the preflight tool. This will retain all the features of your PDF file, and just adjust the page size and scale the content. If you don't have Adobe Acrobat DC Pro, your only option to get a high quality PDF file is to use a 3rd party imposition tool. This could be e.g. an Acrobat plug-in (like Quite Imposing) or a standalone application.
Votes
Translate
Translate
Report
Report
