3 Replies Latest reply on Nov 11, 2016 9:09 AM by oksamurai
    Where have all the Eyeballs Gone!?
    finnandme Level 1
      Now I don't know if I dreamt this, or if there is something different!?
      I thought there were Eye Ball Tags? It seems now they're .. Pupil Range.... I could be going mad!
        • 1. Re: Where have all the Eyeballs Gone!?
          oksamurai Employee Moderator
          If you name something left or right eyeball, it will automatically get tagged as left or right pupil size. That is essentially what the eyeball is for CH - a bounding area for the pupil.
          • 2. Re: Where have all the Eyeballs Gone!?
            finnandme Level 1
            Hi Dave... I thought I might see you here!
            Did I not see... Eye Ball as a Tag!?
            Just testing the right eyeball and the tag... be back in a minute... Spot on, but then again.. I did expect it to work!
            So, Right Pupil Size .... means, this is the area that an object Tagged as Pupil, will be able to move in?  Is the Pupil Range... when it does... because of different sizes of Eye and Pupil and how these may interact differently?
            Another quick question, while I have you captive... I noticed that if you place a + in front of a layer, or group name in Ps, it will set Warp Independence in Ch. If its a layer, It coverts to a group in Ch... so is it only groups that can be set as WI?
            • 3. Re: Where have all the Eyeballs Gone!?
              Eyeball is not a tag, correct. Yes, pupils will try to stay inside the pupil range.
              Yes, currently only groups can be made independent.
