This content has been marked as final.
Show 4 replies
1. Re: Color editing issues
Mylenium Nov 11, 2016 7:29 AM (in response to NickAT)1 person found this helpfulThe color picker by default respects the bit depth and in float mode (32bpc) all colors have ranges between 0 and 1. Change the settings for the input values in the info palette flyout menu or adjust your values accordingly.
Mylenium
3. Re: Color editing issues
Rick Gerard Nov 11, 2016 7:41 AM (in response to NickAT)1 person found this helpfulIf you have the info panel set to Auto the color display will follow the project depth. I was just about to post the same screenshot. This is a common problem for folks that are new to the UI and have not taken the time to study up on the UI. All of this info is available and easy to find by using the Search Help field at the top right corner of AE.
4. Re: Color editing issues
NickAT Nov 11, 2016 7:46 AM (in response to Rick Gerard)Thank you very much for the info @rick Mylenium
