1 Reply Latest reply on Nov 11, 2016 10:24 AM by alann33426378
    Using API, unlocking my iOS key does not work
    alann33426378
      Hello,
      I am quite sure that I am using curl properly to unlock a key using the API. But the response comes back with locked:true and the web interface also confirms that the key was not unlocked. I double/triple/quadruple checked my key password and it is correct. Here is the exact curl command I am using:
      curl -u myemail@mycompany.com -d 'data={"password":"xxxxxxxx"}' -X PUT https://build.phonegap.com/api/v1/keys/ios/123456
      The only substitutions I made so that I could post this on a public forum are these:
      1) I changed my real email address to myemail@mycompany.com
      2) I changed my key password to xxxxxxxx
      3) I changed my key id to 123456 (not sure if key ID is sensitive, but you get the idea)
      When I execute this command I am prompted to enter my password, which again I have double/triple/quadruple checked that I am entering correctly.
      The response that I receive back is as follows:
      {"id":123456,"title":"AdHoc_12012015","platform":"ios","created_at":"2015-12-01 09:09:48 -0800","last_used":"2016-11-11 06:58:46 -0800","link":"/api/v1/keys/ios/123456","default":false,"cert_name":"Certificates_iOS_011 22015_p12.p12","provision":"AdHoc_12012015.mobileprovision","locked":true,"role":"distribu tion"}
      You can see that locked is still "true".
      Any ideas?
