4 Replies Latest reply on Nov 11, 2016 5:45 PM by dwightrph@gmail.com
    Install LR on new Computer
    dwightrph@gmail.com
      I have LR 2.0 disk now worthless but the old computer has updated to LR 5.7.1
      on a 32 bit W7 I am moving to W7 64 bit I have copied MyPictures folder that
      contains
      LR 5 Catalog preview lrdata
      LR 5 Catalog smart preview lfdata
      LR Settings
      and all my photos
      NO BACKUP FILES
      I have a Camera Raw folder
      I have a Export from LR folder (not necessary but will come along for the RIDE)
      This question my seem trite but DO I install LR and NOT OPEN IT first
      OR do I copy these files to the correct folders on the new computer
      THEN install LR
      My concern is will LR over write the arbitrary files it creates
      OR will it be happy to find the old data and not delete or create duplicate files(1)
        • 1. Re: Install LR on new Computer
          If all of those folders and files are arranged the same way the were arranged on the old computer then all you should have to do is install Lightroom 5.7 and go to work. Why do you have a camera raw folder?
          • 2. Re: Install LR on new Computer
            dwightrph@gmail.com Level 1
            Well some how I downloaded LR 2.7 by mistake so I deleted it perhaps that is where Camera Raw folder came from
            So I can install all my folders in the correct location then INSTALL LR 5.7
            • 3. Re: Install LR on new Computer
              If you have put all of your folders in the same folder structure under Pictures so that they are arranged exactly the same as they were on the old computer, then installing Lightroom is all that should be necessary. You might want to take a look at these instructions  for some further insight:
              http://www.lightroomqueen.com/how-move-lightroom-to-new-computer/
              • 4. Re: Install LR on new Computer
                Thanks HI HO it is off to folder installation I GO
                It works like a charm if you place all your folders that are associated with LR from the old system
                in the same folder location on the new system ( went from 32 bit to 64 bit )
                best to look at C:\User\UserName\MyDocuments\MyPictures  (I had my LR Catalog Preview lrdat) files in that folder location
                next place to look is C:\User\UserName\AppData\Roaming\Adobe\Lightroom (copy this one over)
                I keep a separate folder for exporting just get the path and move that folder over
                Then download LR 5.7.1 put the file in a folder called MyBackUP and double click
                When you start this process be sure to have your Serial Number
                I started with LR 2.0 and when I registered I was given a new SN write it down
                I tried to use the old SN and it was declined found the new one and all worked just great
