As part of a rre branding project, I have copied a complete
project to a new folder, made the necessary changes and re built
the index. But when RoboHelp crashes when compiling. The c:/err
file contains the following:
HHA Version 4.74.8702
htmlproc.cpp(114) : Assertion failure: (pszTmp ==
m_pCompiler->m_pHtmlMem->psz)
I've checked and re compiled successfully the original
project.
Any ideas why the project should fail at hte the HHA
stage?
I've found
this
post that seems to indicate this is a problem with the length
of the path to the project's folder. Try shortening the output path
and try again.
Hi Colum, tried this, even tried moving to the root of c:,
but it still won't work. Am trying again from scratch and compiling
again after making changes in stages. Seems ok so far, but I was
wondering whether the index was causing it to fail (haven't got
that far yet)?
Thanks Colum, but it seems to be ok now. Rather than re-run
the index wizard, I've manually changed the entries. Still
compiling ok, so I'm going to leave it for now.
