7 Replies Latest reply on Nov 12, 2016 11:37 AM by Sergey Kritskiy
    AM-code executes dreadfully slow
    Sergey Kritskiy Level 1
      Dear everyone,
      I have one user, on his machine (Windows10 on a i5 skylake Lenovo Thinkpad Yoga + PS CC14) AM code executes awfully slow.
      For example, this takes 0.04s on my old machine and 20s on his
      var ref = new ActionReference();
      ref.putEnumerated(charIDToTypeID("capp"), charIDToTypeID("Ordn"), charIDToTypeID("Trgt"));
      var appDesc = executeActionGet(ref);
      Does anyone know what could be the reason?
      Sergey
        • 1. Re: AM-code executes dreadfully slow
          DBarranca Level 4
          Might depend on the number of Fonts he has installed, or stuff like that.
          As a rule (and when possible! which is not always the case) prepend the app descriptor get with the prop you're interested into, so that you're retrieving that only, e.g.
          // DO
          var ref = new ActionReference ();
          ref.putProperty (stringIDToTypeID ("property"), stringIDToTypeID ("interpolationMethod"));
          ref.putEnumerated (stringIDToTypeID ("application"), stringIDToTypeID ("ordinal"), stringIDToTypeID ("targetEnum"));
          var interpolationDesc = executeActionGet (ref);
          var theInterpolationMethod = typeIDToStringID (interpolationDesc.getEnumerationValue (stringIDToTypeID ("interpolationMethod")));
          alert (theInterpolationMethod);
          // DON'T
          ref.putEnumerated( charIDToTypeID("capp"), charIDToTypeID("Ordn"), charIDToTypeID("Trgt") );
          var applicationDesc = executeActionGet(ref);
          var theInterpolationMethod = typeIDToStringID(applicationDesc.getEnumerationValue(stringIDToTypeID('interpolationMethod')));
          Hope this helps!
          Davide
          • 2. Re: AM-code executes dreadfully slow
            Thanks Davide!
            I need to get an object
                        var curToolOpt = appDesc.getObjectValue(stringIDToTypeID('currentToolOptions'));
            And If I understand correctly, I can't make this faster than getting the whole 'capp' thing
            • 3. Re: AM-code executes dreadfully slow
              SuperMerlin Level 5
              In this case you need to use "tool" to get "currentToolOptions"
              ref.putProperty (stringIDToTypeID ("property"), stringIDToTypeID ("tool"));
              var appDesc = executeActionGet(ref).getObjectValue(stringIDToTypeID("currentToolOptions"));
              • 4. Re: AM-code executes dreadfully slow
                Thanks, SuperMerlin, exactly what I need!
                May I ask you, how can I find certain property stringID? Like with tool in this example? Because I have some other objects I'm getting from 'capp'
                • 5. Re: AM-code executes dreadfully slow
                  SuperMerlin Level 5
                  Try the one that should work first if not you have to experiment with other values.
                  • 6. Re: AM-code executes dreadfully slow
                    I'm sorry I don't think I understood. The one that should work...?
                    • 7. Re: AM-code executes dreadfully slow
                      Ah, I got it. Sorry for spam!
