• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
1
Photoshop Action To Create Guides From Marquee Selection
Engaged ,
Nov 12, 2016 Nov 12, 2016
I looked around on the forums for this answer, but I couldn't find anything specific.
I would like to be able to use the marquee tool to define an area and then create an action where guidelines will be placed against the marquee selection. I may be overthinking this, but is this even possible?
Thanks.
TOPICS
Actions and scripting
Views
2.7K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe
Community Expert ,
Shan-Dysigns​
Hmmh?
I do not have an action for you but you can try a script snippet:
// regards pixxxel schubser
var aDoc = activeDocument;
var Sel = aDoc.selection.bounds;
aDoc.guides.add(Direction.VERTICAL, Sel[0].as('px'));
aDoc.guides.add(Direction.HORIZONTAL, Sel[1].as('px'));
aDoc.guides.add(Direction.VERTICAL, Sel[2].as('px'));
aDoc.guides.add(Direction.HORIZONTAL, Sel[3].as('px'));
Have fun
Votes
Translate
Translate
Report
Report
Engaged ,
Feb 17, 2017 Feb 17, 2017
I create a blank document, use the marquee tool to draw a selection, enact the script, and receive this error.
Votes
Translate
Translate
Report
Report
Community Expert ,
What are your ruler units set to? That script should set the ruler to get the selection bounds in pixels. It does not
var orig_ruler_units = app.preferences.rulerUnits;
app.preferences.rulerUnits = Units.PIXELS; // Set the ruler units to PIXELS
app.preferences.rulerUnits = orig_ruler_units; // Reset units to original settings
JJMack
Votes
Translate
Translate
Report
Report
Engaged ,
Ruler units were px when I tested the script. I'm pretty advanced in javascript/jQuery (web development), but I wish I had the time to experiment in Photoshop.
Votes
Translate
Translate
Report
Report
Community Expert ,
What seem strange is you are getting a error on line 13. that statement  was line 6 in the first script and line 7 in the second  script neither scripts had 13 lines the were shorter. Please post the script your using...
JJMack
Votes
Translate
Translate
Report
Report
Community Expert ,
I can not make it fail no matter what selection I create it sets guides for the selections bounds.  Wait are you using CS2 if I remember selection bounds was broken in cs2?
It does fail in CS2 but with a different error than you get What version of Photoshop are you using?
JJMack
Votes
Translate
Translate
Report
Report
Engaged ,
I am still using CS4, so maybe the issue carried over from CS2.
Votes
Translate
Translate
Report
Report
Community Expert ,
Post the script your using something is strange.
JJMack
Votes
Translate
Translate
Report
Report
Engaged ,
Mar 03, 2017 Mar 03, 2017
My notifications must be turned off. I just happened to catch your reply today.
The script I am using is the one supplied above from
Votes
Translate
Translate
Report
Report
Community Expert ,
If you set ruler units to pixels, there is no need to do the same in the code again.
aDoc.guides.add(Direction.VERTICAL, Sel[0]);
aDoc.guides.add(Direction.HORIZONTAL, Sel[1]);
aDoc.guides.add(Direction.VERTICAL, Sel[2]);
aDoc.guides.add(Direction.HORIZONTAL, Sel[3]);
Have fun
Btw
If I remember right, this will work correct in CS5 and later.
Votes
Translate
Translate
Report
Report
Guide ,
Mar 04, 2017 Mar 04, 2017
Untested but should work in CS2 or newer so long as a selection has been made.
var startRulerUnits = preferences.rulerUnits;
var bnds = getSelectionBounds();
guideLine(bnds[1],"Hrzn",'#Pxl');
guideLine(bnds[3],"Hrzn",'#Pxl');
guideLine(bnds[0],"Vrtc",'#Pxl');
guideLine(bnds[2],"Vrtc",'#Pxl');
preferences.rulerUnits = startRulerUnits;
function guideLine(position, type,unit) {
    //units '#Pxl' pixel '#Rlt' =Relatiive  '#Prc' = percent
    // types: 'Vrtc' & 'Hrzn'
    var desc = new ActionDescriptor();
        var desc2 = new ActionDescriptor();
        desc2.putUnitDouble( charIDToTypeID('Pstn'), charIDToTypeID(unit), position);
        desc2.putEnumerated( charIDToTypeID('Ornt'), charIDToTypeID('Ornt'), charIDToTypeID(type) );
    desc.putObject( charIDToTypeID('Nw  '), charIDToTypeID('Gd  '), desc2 );
    executeAction( charIDToTypeID('Mk  '), desc, DialogModes.NO );
function getSelectionBounds() {
    var doc = activeDocument;
    var l = doc.artLayers.add();
    doc.selection.fill(app.foregroundColor);
    var bnds = l.bounds;
    var hs = doc.historyStates;
    if (hs[hs.length-2].name == "Layer Order") {
      doc.activeHistoryState = hs[hs.length-4];
    } else {
      doc.activeHistoryState = hs[hs.length-3];
    for (var i = 0; i < bnds.length; i++) {
      bnds = bnds.value;
    return bnds;
Votes
Translate
Translate
Report
Report
Community Expert ,
Selection Bounds does not work in CS2 I had to code around that bug in CS2
JJMack
Votes
Translate
Translate
Report
Report
Guide ,
I am not using selection bounds, I am using Layer bounds and that does work in CS2.
Votes
Translate
Translate
Report
Report
Community Expert ,
Mar 05, 2017 Mar 05, 2017
I did not look at the code I just read the function name Using Layer bounds is how I coded around the selection bounds bug in cs2.
JJMack
Votes
Translate
Translate
Report
Report
Engaged ,
Apr 22, 2017 Apr 22, 2017
LATEST
My email notifications must be turned off because I just now noticed your reply.
Your code worked. I know javascript, but not enough when it comes to Photoshop, so I can somewhat understand the code, but not necessarily what makes it work. The code worked in all the ways I would try to apply it, so thanks for providing it.
Votes
Translate
Translate
Report
Report
