1 Reply Latest reply on May 9, 2017 4:34 AM by GuyUK
    Audio encoding failed...
    Udo V
      I try to export and the response I get is "Audio incoding failed. If Audio is in 2 pass VBR encoding mode, try either CBR or 1 pass encoding. I have worked on this project for over a year, Does anyone know how to correct this?
        • 1. Re: Audio encoding failed...
          GuyUK Level 2
          I have had exactly the same problem today.  I have never had it before although I have exported using the same parameters on a regular basis.  I am exporting from a 1920 x 1080 x 25 timeline to half res PAL wmv files.
          I assumed that something on the timeline was corrupted, so I switched off the timelines being exported one by one to isolate the problem.  It turned out to be on Audio one.  I checked the audio clips to try and find some error but discovered nothing.  Eventually I moved all the clips on Audio one to another audio timeline and the problem was solved.
          It doesn't make any sense, but it worked for me.  Sorry I cannot offer a more rational solution,  I hope this helps?
