1 Reply Latest reply on Nov 13, 2016 12:01 AM by Mylenium
    What can I improve?
    ronkinderz Level 1
      My projects (1080p) are between 2-10 minutes long and they contain the same template as following:
      -Particles emitter (Particular) which emits from outside of the screen (do I need to trim that in some sort so that AE will not process what's going outside?) that reacts to music (Sound Keys) + Camera layer.
      -4 Audio Spectrums that react to music (Sound Keys) which are in a comp within the main comp.
      -720p footage duplicated also in a pre-comp inside the main comp, also reacting to Sound Keys.
      -Looped GIF as background
      -Still image
      -Music track
      My specs:
      i7 5820k
      16GB DDR4 2133MHz
      GTX 780TI
      GA-X99 SLI
      I've got 2 SSD's , one that the system and AE runs from and another for disk cache and conformed media cache. also 2 regular hard drives.
      While export rendering CPU is on 23% and RAM on 55% workload, so i'm guessing improving those won't help.
      Export rendering takes about four hours for each composition, I would appreciate recommendations on optimizing rendering time.
        • 1. Re: What can I improve?
          Weren't we over this already? Everything seems perfectly normal, given that you use a complex particle simulation and time-remapped footage, which causes redundant calculations for sampling multiple frames and blending them...
          Mylenium
