I think you need to look at this in a different way. Where is
the help installed? If it is on a server, then webhelp or flashhelp
are the correct outputs. If local, then CHMs are the output you
want.
The short answer to you question about the size is while the
source may be the same, the outputs are very different. If you
created a printed output you wouldn't expect the DOC file to also
be the same size. Is the issue coming from your developers and is
it really about file size or the number of files. Either way, as
above that should not be the consideration. The type of help for
the location is what matters.
