I am currently attempting to use Ray-Traced 3D function for extruding text. I've ran into a bit of a snag. Currently I have one Comp a simple text font, BUT anytime I try to type "X" the whole text goes away. It stays if I do it in lower-cased. 3D Layer option is checked. It does it with any font I use. But doesn't give me any issues with any other number or letter Caps or no Caps. Anyone have any ideas on why this is happening?
Shouldn't matter specs but doesn't hurt to state.
Win10 Pro
I7 6700k
16 gb Ram
GTX 970
I am updated to the most recent version of adobe. I have tried a different Comp, New projects, and restarts. No change in it. When it's in standard or 2d mode it shows up fine. Only in 3D will it not show up.
That simply sounds like a keyboard issue. Check your configuration and in particular any external tools that may remap system-wide shortcuts like instant messengers, screenshot tools, customizabble mouse buttons, gaming keyboard tools and so on.
Mylenium
I have swapped keyboards and mouse, none have any programmable buttons or anything. I have tried it on my second rig and I still run into the same issue. Both rigs don't have any third-party apps like instant messenger. All they have on them is Adobe products and stock footage.
what's your exact Ae version? note that CC2017 comes with the much better replacement the Cinema4D Renderer. it is faster, and works on the CPU, not GPU. try to narrow down your problem. one comp, one element. if it still persists, upload the project file - we can take a look what's going on there. screenshots would be helpful tool
Well, you shouldn't. It's considered an Obsolete Feature in recent versions of AE. You should be using C4D Lite, which is better. But Mylenium is almost surely correct in his diagnosis. So read his words carefully.
