5 Replies Latest reply on Nov 14, 2016 9:47 AM by whsprague
    Elements premiere 2015
    brettc19847802
      Hi there,
      I took up the trial for elements premiere 2015, and then upgraded to the full programme and downloaded it. However when i go onto element premiere its still coming up saying i'm on a trial basis?
      any suggestions....
        • 1. Re: Elements premiere 2015
          Delete the rendered files. They are in the same directory folder as your project files, in the sub-folder called Adobe Premiere Elements Preview Files.
          Also, go into Premiere Elements' Preferences and, on the Media page, delete the Media Cache.
          • 2. Re: Elements premiere 2015
            brettc19847802 Level 1
            Hi Steve, thanks for this, tried this and it still hasn't worked.
            If I delete the whole programme files and reload it from adobe would this work, or is this too extreme?
            • 3. Re: Elements premiere 2015
              It doesn't hurt to try.
              But the real question is, Are you seeing this banner on your new projects or only on projects you were editing before you activated the program?
              If you are only seeing the banner on projects you started before you activated the program, then you just need to delete the render files.
              However, if you are seeing this banner on new projects you've created since you bought and activated the program, then you have, for some reason, not actually activated the program and you are still working on the trial version.
              • 4. Re: Elements premiere 2015
                LariosoDog Level 1
                Wild idea - is your serial registered on your Adobe ID account?
                I bought on disks, so not sure what is done automatically when buying digital license.
                • 5. Re: Elements premiere 2015
                  whsprague Level 4
                  Either way, it will repeatedly ask you to enter the serial number when you install it.  If you haven't bought one yet on a box or download, it will give you the choice of running it for 30 days.  While in the trial mode it puts a watermark on your work.
                  It might be best to limit trial mode use to play, learning and testing.  When ready for a "real" project, it might be best to buy the license before starting.   Then you don't have to deal with the watermark.
