0 Replies Latest reply on Dec 3, 2008 7:12 AM by RichardG
    Sudden cfhttp  failure - need help!
    RichardG Level 1
      The cfhttp code below has been running perfectly for a few years (certain specifics removed to protect my job!).
      It suddenly began to fail on our Win 2000 CF7 production server. Testing it in development and other CF servers it runs perfectly. It is a critical part of an online app. that runs nightly.
      Does anybody have ANY clue why this might be failing now and just on this server?
      <cftry>
      <cfhttp method="get"
      url=" http://<remote_sitetextfile.txt>"
      path = "c:\temp\"
      file = "filename.txt"
      throwonerror = "yes">
      </cfhttp>
      <cfcatch type="any">
      <cfoutput>
      #cfcatch.Message#<br />
      #cfcatch.Type#<br />
      #cfcatch.Detail#<br /><br />
      </cfoutput>
      <cfdump var="#cfcatch#">
      </cfcatch>
      </cftry>
      The results of the debugging code in cfcatch are:
      Connection Failure: Status code unavailable
      COM.Allaire.ColdFusion.HTTPFailure
      struct
      Detail [empty string]
      Message Connection Failure: Status code unavailable
      StackTrace coldfusion.tagext.net.HttpTag$HttpConnectionFailureException: Connection Failure: Status code unavailable at coldfusion.tagext.net.HttpTag.connHelper(HttpTag.java:946) at coldfusion.tagext.net.HttpTag.doEndTag(HttpTag.java:1004) at cfrouting_test2ecfm490324701.runPage(C:\Inetpub\wwwroot\..............\routing_test.cfm:8 ) at coldfusion.runtime.CfJspPage.invoke(CfJspPage.java:152) at coldfusion.tagext.lang.IncludeTag.doStartTag(IncludeTag.java:349) at coldfusion.filter.CfincludeFilter.invoke(CfincludeFilter.java:65) at coldfusion.filter.ApplicationFilter.invoke(ApplicationFilter.java:225) at coldfusion.filter.RequestMonitorFilter.invoke(RequestMonitorFilter.java:51) at coldfusion.filter.PathFilter.invoke(PathFilter.java:86) at coldfusion.filter.ExceptionFilter.invoke(ExceptionFilter.java:69) at coldfusion.filter.BrowserDebugFilter.invoke(BrowserDebugFilter.java:52) at coldfusion.filter.ClientScopePersistenceFilter.invoke(ClientScopePersistenceFilter.java:2 8) at coldfusion.filter.BrowserFilter.invoke(BrowserFilter.java:38) at coldfusion.filter.GlobalsFilter.invoke(GlobalsFilter.java:38) at coldfusion.filter.DatasourceFilter.invoke(DatasourceFilter.java:22) at coldfusion.filter.RequestThrottleFilter.invoke(RequestThrottleFilter.java:115) at coldfusion.CfmServlet.service(CfmServlet.java:107) at coldfusion.bootstrap.BootstrapServlet.service(BootstrapServlet.java:78) at jrun.servlet.ServletInvoker.invoke(ServletInvoker.java:91) at jrun.servlet.JRunInvokerChain.invokeNext(JRunInvokerChain.java:42) at jrun.servlet.JRunRequestDispatcher.invoke(JRunRequestDispatcher.java:257) at jrun.servlet.ServletEngineService.dispatch(ServletEngineService.java:541) at jrun.servlet.jrpp.JRunProxyService.invokeRunnable(JRunProxyService.java:204) at jrunx.scheduler.ThreadPool$DownstreamMetrics.invokeRunnable(ThreadPool.java:318) at jrunx.scheduler.ThreadPool$ThreadThrottle.invokeRunnable(ThreadPool.java:426) at jrunx.scheduler.ThreadPool$UpstreamMetrics.invokeRunnable(ThreadPool.java:264) at jrunx.scheduler.WorkerThread.run(WorkerThread.java:66)
      TagContext array
      1 struct
      COLUMN 0
      ID CFHTTP
      LINE 8
      RAW_TRACE at cfrouting_test2ecfm490324701.runPage(C:\Inetpub\wwwroot\..........\routing_test.cfm:8)
      TEMPLATE C:\Inetpub\wwwroot\.............\routing_test.cfm
      TYPE CFML
      Type COM.Allaire.ColdFusion.HTTPFailure
