3 Replies Latest reply on Nov 15, 2016 12:40 PM by Jeff_Coatsworth
    RoboHelp 2015 styles not appearing in generated output
    GeoffreyMarnell
      Hi
      I have imported  a FM book into RH2015 and mapped FM styles to HTML styles. The text is correctly styled in the RH editor window, but when I generate WebHelp (both varieties), the output is not styled accordingly.
      When I look at the raw HTML, I can see that the text in question is wrapped correctly. For example, <span class="FM_bold">Status</span> ) is in the code, but the wrapped text does not get bolded. It seems as if the CSS is not being read, even though it is correctly referenced in the meta-tags.
      Any help?
      Geoffrey Marnell
