It runs the ExpManCmd.exe to install the panel plug-in can not be installed returns the status value of -403.
There was no problem in Premiere Pro CC 2015.4, but is a situation that can not resolve the problem Premiere Pro CC 2017.
*OS is Windows7.
I am developing the panel plug-in of Premiere Pro of my for customers.
Customer's environment can not use a internet.
For this reason it is necessary to install by ExpManCmd.exe.
Thank you.
I have solved the problem.
On my PC there were two problems with running ExManCmd.
1. 'Failed to install, status = -403!'
I found a workaround.
Uninstalling 'Extention Manager CC' solved it.
2. 'Failed to install, status = -411!'
This error code could be solved with your advice.
Thank you very much.
What versions of PPro does your panel's manifest say it supports?
This is the version description in manifest.html of my plugin.
<ExecutionEnvironment>
<HostList>
<Host Version="[7.0,11.0]" Name="PPRO"/>
</HostList>
<LocaleList>
<Locale Code="All"/>
</LocaleList>
<RequiredRuntimeList>
<RequiredRuntime Version="6.0" Name="CSXS"/>
</RequiredRuntimeList>
</ExecutionEnvironment>
That should work.
Perhaps you're running an older version of ExManCmd? Here's the latest.
Can you post the .zxp somewhere, for me? [Our mail gateway will block it.]
ExManCmd seems to be the latest version.
I will inform the date of the ExManCmd I am using.
2016/10/21 21:30 1,045,680 adobe_caps.dll
2016/10/21 21:30 238,792 ExManBridgeTalkCmd.exe
2016/10/21 21:30 1,824,456 ExManCmd.exe
2016/10/21 21:30 5,334,728 ExManCoreLib64.dll
2016/10/21 21:30 20,974 ExManCoreLib64.lib
2016/10/21 21:30 1,050,312 ExManEscalatedPrivilegeServer.exe
2016/10/21 21:30 3,009,736 ExManZxpSign.dll
2016/10/21 21:30 1,682,088 IMSLib.dll
2016/10/21 21:30 1,657,032 libeay32.dll
2016/10/21 21:53 203 README
2016/10/21 21:30 351,944 ssleay32.dll
2016/10/21 21:30 153,800 VulcanMessage4.dll
2016/10/21 21:32 188,825 XManConfig.xml
I would like to send you zxp.
How about sending my Creative Cloud Assets link to your email?
Sure; b b b at adobe dot com
I posted the zxp.
Thank you.
I received it, and I too get an installation failure; -411, compatible app not found.
Could you change this line, build a new .zxp, and see whether it helps?
Old:
<Host Name="PPRO" Version="[7.0,11.0]" /> |
New:
<Host Name="PPRO" Version="7.0" /> |
I tried based on advice from you.
However, ExManCmd execution result was -403.
The figure below is the command prompt in windows of my PC.
Just to be sure, i will send zxp to you.
