4 Replies Latest reply on Nov 14, 2016 10:49 PM by Pavel Homeriki
    PHP Form not working
    peterm47582768 Level 1
      I can't  get the contact form working on third party server. Works OK uploaded to business catalyst.
      The PHP check ( http://my-site.com/scripts/form_check.php
      gives all green checkmarks.
      I've contacted my hosting company (cloud next) and they have asked if:-
      quote
      Hi Peter,
      Can you confirm that in the configuration of the script you have configured an SMTP server as well as a valid to/from email address as configured on this account?
      Kind regards
      Cloud Next
      Unquote
      As I'm not a PHP developer i'm not sure.
      Please advise, If I can't get forms to work I'll be terminating my Adobe Muse subscription.
      regards
      Peter
        • 1. Re: PHP Form not working
          Pavel Homeriki Adobe Community Professional
          Muse form works through PHP MAIL, not SMTP. Some hosting providers do not support php mail. Apparently your hosting provider is one of these. To customize your form via SMTP, you must be php coder. And even if you are able to do this through code, it will be still some disadvantages - you have every time separately from the muse place handler php file on the server. A much easier way - just change the hosting provider. It's poor tone if the hosting provider does not support php mail.
          • 2. Re: PHP Form not working
            I've contacted the hosting provider again, their repose was:-
            quote
            Hi Peter,
            PHP Mail is supported, but for us to be able to see what is going on (checking the mail logs etc to see what is happening with the email on your form) it does need to be routed through an SMTP server.
            Kind regards
            Cloud Next
            unquote
            I responded
            Ok, so I suppose Adobe muse forms are not going to work on Cloud Next servers without addition scripting?
            they responded
            quote
            Hi Peter,
            We do always recommend configuring an SMTP server with a valid to/from mailbox as configured on the hosting when using forms on our platform.
            Kind regards
            Cloud Next
            unquote
            Not sure where that leaves me, between a rock and a hard place I suppose. I have 5 website with Cloud Next (designed in Freeway Pro with working contact forms). Muse for some reason does not seem the work though.
            • 3. Re: PHP Form not working
              Does anyone know what the script form_check.php actually does? My hosting company is querying the code below.
              quote
              Hi Peter,
              Looking through those scripts and I don't think it's setup right, looking at the script form_check.php there is this line of code:
              $sent = mail("recipient@example.com", "Hi", "test message", "From: sender@example.com");
              obviously those details appear to be incorrect.
              Kind regards
              unquote
              • 4. Re: PHP Form not working
                Change your hoting provider. In normal hosting it works by default.
