I use indesign first time with two screens, when I set the indesing window on second screen , the hidden tools menus are left of tool barr not on right
I reset the defaults, still the same
Please help
Regards
Jean
I think this has more to do with your operating system and monitor settings than it does with InDesign. If you tell us what OS you have (Windows 10, Mac OS 10.9, etc.), someone will probably be able to give you specific help.
I have Windows 10 last update, but every thing woks fine with Photoshop, used on the same second screen with the same system setup
Thanks for your help
I don't use Windows, so I can't help you, but you should get a reply from a fellow Windows user very soon.
Has some body a solution for this problem , or is it a bug ?
Try restoring your InDesign preferences:
Trash, Replace, Reset, or Restore the application Preferences
Thanks, I tried, it does not help, problem still there
But in the referred discussion there are two files, I find only one
I am on Windows 10 last update and Indesign CC 2017.0
I find only : C:\Users\xxxxx\AppData\Roaming\Adobe\InDesign\Version 12.0\fr_FR\InDesing Defaults
Is there an other file ?
Regards
Has some body a solution for this problem ?
Hidden menus even display to the left when using a 2 column toolbar, but only when the window is on my right monitor. It's odd. Switching to a single row panel knocks it over to the top of my left screen as if the INDD window is over there. I smell a bug.
Win 7 here.
Windows likes to pop things open on the primary monitor, in my experience.
I fully agree, I had a discussion with Adobe support, It seems I am the only one in the world having this problem, so that's not a bug !!!!!!
Thanks for the help
I have exactly the same issue with the latest InDesign on Win7.
My primary monitor is on the right side and the second one on the left and when using the toolbar on my primary monitor the popup menus fire up on the left side...
The red line is where my primary monitor ends.
If I will have this bug, I will never known about it. You can ask me - Why?
the answer is simple: use shortcuts
