I am using RHv6, my output is FlashPro, I was wondering if
there was a simple way to change the outcome of searches. I located
a article that stated if the whfhost.js file was changed with one
line of code var rg = new RegExp(gsCW,"ig"); that the results would
be that the most likely topic would appear at top and not in Alpha
form.
Does anyone know besides using Zoomsearch, to modify a .js
file to change the outcome of the search feature. What would be
perfect is if the person has drilled down to a specific topic and
then uses the search, it only searches within that particular topic
folder.
Thank you for your help
