3 Replies Latest reply on Nov 15, 2016 9:04 AM by MSSDedalus
    New File issues in Mac Sierra
    MSSDedalus Level 1
      I'm having issues while creating File objects in Sierra:
      var myFile = new File("/Users/myusername/Documents/Sample.jpg");    //Of course this file exists
      Fails many times (File not found), but it seems not always or at least not in all computers
      var myFile = new File("~/Documents/Sample.jpg");
      works fine and  myFile.fsName returns the full path as specified in the first option "/Users/myusername/Documents/Sample.jpg"
      Something in Sierra's file system may have changed, one user reported he solved this by reinstalling OS.
      To reproduce the error just enable script logs and try to place a picture in Photoshop, then execute the script with ExtendedScript, the path notation used in the log doesn't works.
      Any help would be appreciated.
        • 1. Re: New File issues in Mac Sierra
          MSSDedalus Level 1
          If it helps:
          I have been able to reproduce it also at the new CC 2017 start screen, if I try to reopen a document from there it raises a scripting error. The same document opened at Photoshop's menu (recent list) opens fine.
          As far as I know from my tests It affects only files saved into the Documents folder.
          • 2. Re: New File issues in Mac Sierra
            JavierAroche Level 3
            Hey MSSDedalus, I just ran a few tests on my system and everything seems to work fine, even opening from the Documents folder.
            I also tried setting the new File as a variable before running the "Opn " ActionDescriptor, and it worked. I tested PSDs, PNGs and JPGs.
            Here's what I'm running:
            macOS Sierra 10.12.1
            Photoshop 2015.0.0
            It might be an issue with a new version of Photoshop? I don't have a 2015.5 or a 2017 version to test with, unfortunately.
            • 3. Re: New File issues in Mac Sierra
              MSSDedalus Level 1
              Thanks for your answer.
              I believe the problem is on how Photoshop File object reads the file path in Sierra for the users folder but as I mentioned it doesn't happens in all computers, really weird.
              The issue has been reported by 2 users and I could also reproduce it with Sierra 10.12.1 and CC 2017.0.0
              From my tests I know that the volume has to be included or "~/" must be used but results from scripting listener like "/Volumes/Users/MyUser/Documents/Sample.jpg" doesn't work.
