5 Replies Latest reply on Nov 16, 2016 1:01 PM by TDSwift
    Animate CC Loop
    TDSwift
      I am trying to create a loop using the below:
      "loop" is a frame label 1 frame after the below on the main timeline.
      Can someone find what is keeping this from working?
      Thank you!
      var i = 0;
      i++;
      if (i < 2) {
      this.play("loop");
      } else if (i > 2) {
        this.stop();
        • 1. Re: Animate CC Loop
          ClayUUID Adobe Community Professional
          You initialize i to zero every time you enter the frame.
          The variable i only exists in that frame.
          The conditional logic doesn't account for i being equal to 2.
          There's no such function as .play().
          There's no need to use a frame label when you're just advancing to the next frame.
          • 2. Re: Animate CC Loop
            rezun8 Level 4
            I use this in my banner ads to loop the creative 2x:
            if(!this.alreadyExecuted){
            this.alreadyExecuted=true;
            this.loopNum=1;
            } else {
            this.loopNum++;
            if(this.loopNum==2){
            this.stop();
            • 3. Re: Animate CC Loop
              I don't know why people are still using that ungainly code when a perfectly functional two-liner has been posted here many times:
              if (!this.looped) this.looped = 1;
              if (this.looped++ > 2) this.stop();
              • 4. Re: Animate CC Loop
                rezun8 Level 4
                sorry clay it wasnt to your standards, I will use your updated code from now on.
                Cheers
                • 5. Re: Animate CC Loop
                  TDSwift Level 1
                  Thank you for the tips @ClayUUID. You got me on the right track. After making the adjustments you suggested, the loop works as expected.
                  /*defined i=0 in first frame
                  placed this.gotoAndPlay("restart"); on last frame
                  placed "restart" label on first frame */
                  if (i < 3) {
                  i++;
                  } else if (i == 3) {
                    this.stop();
                  ClayUUID  Nov 15, 2016 8:28 PM (in response to Tony Dilger)
                  ANSWER!
