6 Replies Latest reply on Nov 17, 2016 12:45 AM by Sudha K
    Crop PDF
    Sudha K
      HI,
           Sorry i don't know  the place to write this so writing here...
           I am croping pdf to trim size using applescript.
           1.  Crop Pages -> Get the Trim box values
           2.  Place the values (T, L, B, R) to the Crop box.
           3.  Select All radio button
           4.  Click Ok.
           Following these steps in apple script but after cropping the pdf (ie., after completing script) no changes in pdf.  Actually values are asigned to crop process but no changes.  I could not get the issue.  Can anyone help me?
      Code:
      ------------- Process --------
      set pdfFile to choose file
      my mainProcess(pdfFile)
      display dialog "Process Completed!!!"
      -------------- Functions ---------
      on mainProcess(pdfFile)
          local trimboxFlg, cropboxFlg
          set cropboxFlg to 0
          set trim_box to ""
          tell application "Adobe Acrobat Pro"
              activate
              open pdfFile
              delay 1
              set trimVals to my getTrimValues()
              --display dialog "trimVals " & trimVals
              --set trimVals to {0.545, 0.545, 0.545, 0.545}
              delay 1
              my cropProcess(trimVals)
          end tell
      end mainProcess
      on cropProcess(trimVals)
          local cropboxFlg, boxTypeValue2
          set boxTypeValue2 to "CropBox"
          set cropboxFlg to 0
          tell application "System Events"
              tell process "Acrobat"
                  click menu item "Crop Pages..." of menu 1 of menu bar item "Document" of menu bar 1
                  if exists window "Crop Pages" then
                      tell window "Crop Pages"
                          tell pop up button 1 of group "Crop Margins"
                              set boxType to value of item 1 as string
                              if boxType is not equal to boxTypeValue2 then
                                  click
                                  click menu item boxTypeValue2 of menu 1 --    click TrimBox
                                  set cropboxFlg to 1
                              else
                                  set cropboxFlg to 1
                              end if
                          end tell
                          --click button "Revert To Selection" of group "Margin Controls" of group "Crop Margins"
                          if cropboxFlg is equal to 1 then --     Get trim box values
                              set value of text field 1 of group "Margin Controls" of group "Crop Margins" to (item 1 of trimVals) as string
                              set value of text field 2 of group "Margin Controls" of group "Crop Margins" to (item 2 of trimVals) as string
                              set value of text field 3 of group "Margin Controls" of group "Crop Margins" to (item 3 of trimVals) as string
                              set value of text field 4 of group "Margin Controls" of group "Crop Margins" to (item 4 of trimVals) as string
                          end if
                          click radio button "All" of group "Page Range"
                          click button "OK"
                      end tell
                  else
                      display dialog "ELSE..."
                  end if
              end tell
          end tell
      end cropProcess
      on getTrimValues()
          local trimTop, trimBottom, trimLeft, trimRight
          local trim_box, trimboxFlg
          set boxTypeValue1 to "TrimBox"
          set trimboxFlg to 0
          set trimTop to 0
          set trimBottom to 0
          set trimLeft to 0
          set trimRight to 0
                              if boxType is not equal to boxTypeValue1 then
                                  click
                                  click menu item boxTypeValue1 of menu 1 --    click TrimBox
                                  set trimboxFlg to 1
                              else
                                  set trimboxFlg to 1
                              end if
                          end tell
                          if trimboxFlg is equal to 1 then
                              set trimTop to the value of text field 1 of group "Margin Controls" of group "Crop Margins" as string
                              set trimBottom to the value of text field 2 of group "Margin Controls" of group "Crop Margins" as string
                              set trimLeft to the value of text field 3 of group "Margin Controls" of group "Crop Margins" as string
                              set trimRight to the value of text field 4 of group "Margin Controls" of group "Crop Margins" as string
                           end if
                    end tell
                  end if
              end tell
          end tell
          return {trimTop, trimBottom, trimLeft, trimRight}
      end getTrimValues
      - Sudha K
        • 1. Re: Crop PDF
          There is a JavaScript method for setting the CropBox.
          • 2. Re: Crop PDF
            Sudha K Level 1
                 I am not familiar in acrobat scripting. I want to do this for batch and also need to write error report if there is any issue occur.
                 I feel its easy in applescript also i can call applescript  through java.  So using applescript.
            • 3. Re: Crop PDF
              Adobe have thousands of pages of documentation on their supported interfaces in the Acrobat SDK. They don't support this sort of UI automation, so there won't be any information to help you do that.
              For batch why not just use Acrobat actions?
              • 4. Re: Crop PDF
                Sudha K Level 1
                Can we write report file like csv using scripting or actions?
                Actually i completed all process by applescript. When i run the code its fully completed but the process of crop is not happen.
                • 5. Re: Crop PDF
                  Acrobat JavaScript is not good for writing reports, and actions could only use JavaScript. So you could keep the AppleScript for this and use the AppleScript interface to JavaScript to set the cropping.
                  Did you check that if you complete the SAME sequence of steps manually in the UI that the crop happens as you expect? This is the only tip I can give, we have no way to help you fix problems in UI automation, Adobe have no interest in that. I know there is enthusiasm for such unsupported methods though, maybe you'll find an AppleScript forum.
                  • 6. Re: Crop PDF
                    Sudha K Level 1
                         yes i have checked manually its working fine. I will check it as you suggested.
                         Thank you so much...
