23 Replies Latest reply on Nov 28, 2016 2:13 AM by Oriup
    List of reduced or increased images with value
    Oriup Level 1
      Can anyone modify jongware script below:
      I need only those image list which is reduced or increase image size with percentage value but this script get all the image with percentage value. I do not need which image is 100%.
      app.activeDocument.viewPreferences.rulerOrigin = RulerOrigin.PAGE_ORIGIN;
      list = [];
      imgs = app.activeDocument.allGraphics;
      unitname = getCurrentUnit();
      for (i=0; i<imgs.length; i++)
      scale = roundMe(imgs[i].horizontalScale,1);
      // some fair rounding
      list.push (imgs[i].itemLink.name+'\t'+scale+'%');
      // alert (list.join('\r')); exit();
      defaultFile = new File (Folder.myDocuments+"/"+app.activeDocument.name.replace(/\.indd$/i, '')+".xls");
      if (File.fs == "Windows")
      writeFile = defaultFile.saveDlg( 'Save report', "Plain text file:*.txt;All files:*.*" );
      else
      writeFile = defaultFile.saveDlg('Save report');
      if (writeFile != null)
      if (writeFile.open("w"))
        writeFile.encoding = "utf8";
        writeFile.write (list.join("\r")+"\r");
        writeFile.close();
      function roundMe(val,to)
      var t = 1;
      while (to-- > 0) t *= 10;
      return Math.round(val*t)/t;
      function getCurrentUnit ()
      switch (app.activeDocument.viewPreferences.horizontalMeasurementUnits)
        case MeasurementUnits.POINTS: return "pt";
        case MeasurementUnits.PICAS: return "pt";
        case MeasurementUnits.INCHES: return "in";
        case MeasurementUnits.INCHES_DECIMAL: return "in";
        case MeasurementUnits.MILLIMETERS: return "mm";
        case MeasurementUnits.CENTIMETERS: return "cm";
        case MeasurementUnits.CICEROS: return "c";
        case MeasurementUnits.AGATES: return "ag";
        default: alert ("Oh, come on!"); exit(0);
      Regards,
      Sumit
        • 1. Re: List of reduced or increased images with value
          tpk1982 Level 4
          Simply add a if condition in line 9.. it will work now
          list = [];
          if(imgs[i].horizontalScale!=100){
          list.push (imgs[i].itemLink.name+'\t'+scale+'%'); }
          else
            writeFile.close();
          var t = 1;
          • 2. Re: List of reduced or increased images with value
            Oriup Level 1
            Thank you so much!
            • 3. Re: List of reduced or increased images with value
              Don't forget that there is also a vertical scale value.
              And that could be a different to the horizontal one.
              And how about skewd images?
              ( shearAngle )
              Regards,
              Uwe
              • 4. Re: List of reduced or increased images with value
                Oriup Level 1
                Thank you Laubender,
                Yes, you are right.
                Can you do that?
                Kind Regards,
                Sumit
                • 5. Re: List of reduced or increased images with value
                  Oriup Level 1
                  Dear TPK,
                  Can you help me?
                  How to right in this forum as a script format as you write?
                  Kind Regards,
                  Sumit
                  • 6. Re: List of reduced or increased images with value
                    tpk1982 Level 4
                    Hi Sumit,
                    Here is the version with vertical scale value..
                    list = [];
                    vscale = roundMe(imgs[i].verticalScale,1);
                    if((imgs[i].horizontalScale!=100) ||(imgs[i].verticalScale!=100)){
                    list.push (imgs[i].itemLink.name+'\t'+scale+'%'+'\t'+vscale+'%'); }
                    else
                      writeFile.close();
                    var t = 1;
                    • 7. Re: List of reduced or increased images with value
                      tpk1982 Level 4
                      For script format.. use like below
                      2 people found this helpful
                      • 8. Re: List of reduced or increased images with value
                        Oriup Level 1
                        Thank you so much!
                        • 9. Re: List of reduced or increased images with value
                          Oriup Level 1
                          Dear TPK,
                          Can I open, save report automatically?
                          Sumit
                          • 10. Re: List of reduced or increased images with value
                            tpk1982 Level 4
                            like below?
                            list = [];
                            defaultFile = new File (app.activeDocument.name.replace(/\.indd$/i, '')+".xls");
                            if (defaultFile.open("w"))
                              defaultFile.encoding = "utf8";
                              defaultFile.write (list.join("\r")+"\r");
                              defaultFile.close();
                              defaultFile.execute();
                            var t = 1;
                            • 11. Re: List of reduced or increased images with value
                              Oriup Level 1
                              Dear TPK,
                              Works fine but need to save report at Desktop also.
                              Regards,
                              Sumit
                              • 12. Re: List of reduced or increased images with value
                                tpk1982 Level 4
                                Change line 15 to..
                                var defaultFile = new File("~/Desktop/Report.xls");
                                • 13. Re: List of reduced or increased images with value
                                  tpk1982 Level 4
                                  or..
                                  var defaultFile = new File("~/Desktop/"+app.activeDocument.name.replace(/\.indd$/i, '')+".xls");
                                  • 14. Re: List of reduced or increased images with value
                                    Oriup Level 1
                                    Dear TPK,
                                    If you do not mind, can I ask your name please?
                                    Both of your comment is file save only, not opening automatically.
                                    Regards,
                                    Sumit
                                    • 15. Re: List of reduced or increased images with value
                                      tpk1982 Level 4
                                      HI Sumit,
                                      My name is Karthi.
                                      Using    defaultFile.execute();  is to open the xls file automatically after you ran the script...
                                      Just close the excel and try again
                                      • 16. Re: List of reduced or increased images with value
                                        Oriup Level 1
                                        Dear Karthi,
                                        Thank you so much!
                                        I appreciated your reply.
                                        I have used below script:
                                        list = [];
                                        var fName = app.activeDocument.name.replace(/\.indd$/i, '')+".txt";
                                        defaultFile = new File ("~/Desktop/"+fName);
                                        var t = 1;
                                        Sumit
                                        • 17. Re: List of reduced or increased images with value
                                          Oriup Level 1
                                          Dear Karthi,
                                          When I use below line, that is not working.
                                          Can you tell me what I am doing wrong?
                                          if((imgs[i].horizontalScale!=100) ||(imgs[i].verticalScale!=100) || (imgs[i].imageTypeName != "PDF")){
                                          If I use EPS or JPEG then working but When I use PDF then not working.
                                          Sumit
                                          • 18. Re: List of reduced or increased images with value
                                            tpk1982 Level 4
                                            Hi..
                                            In your if condition you ignored the image type of PDF if comes.. So only you not get any results..try like below
                                            if((imgs[i].imageTypeName == "PDF")){   \\ hope you know the difference of this != "PDF".. not sure why you check this
                                            • 19. Re: List of reduced or increased images with value
                                              Oriup Level 1
                                              Dear Karthi,
                                              I do not want to reduced pdf list because, In my document I have used pdf as a mini in teacher edition.
                                              Same condition working with eps, ai and jpeg but not working with pdf only.
                                              Sumit
                                              • 20. Re: List of reduced or increased images with value
                                                tpk1982 Level 4
                                                better try like
                                                if(imgs[i].imageTypeName == "PDF"){continue;}
                                                if((imgs[i].horizontalScale!=100) ||(imgs[i].verticalScale!=100){
                                                also like below
                                                if((imgs[i].horizontalScale!=100) ||(imgs[i].verticalScale!=100) || (imgs[i].imageTypeName != "Adobe PDF")){
                                                or
                                                if((imgs[i].horizontalScale!=100) ||(imgs[i].verticalScale!=100) || (imgs[i].imageTypeName !== "PDF")){
                                                • 21. Re: List of reduced or increased images with value
                                                  Oriup Level 1
                                                  Dear Karthi,
                                                  Thank you so much!
                                                  Today, I learned from you "PDF" is not working but "Adobe PDF" is working.
                                                  Below code working nicely.
                                                  But, Now problem is: Adobe PDF also escape .ai file. I need escape only .pdf file.
                                                  Regards
                                                  Sumit
                                                  • 22. Re: List of reduced or increased images with value
                                                    tpk1982 Level 4
                                                    HI..
                                                    this maybe a solution.. try and let me know
                                                    if(app.activeDocument.allGraphics[i].itemLink.name.match(/\.pdf$/i) != null) {continue;}
                                                    • 23. Re: List of reduced or increased images with value
                                                      Oriup Level 1
                                                      Dear Karthi,
                                                      Yes, your code is working nicely.
                                                      You are great.
                                                      Thank you so much.
                                                      Sumit
