6 Replies Latest reply on Nov 17, 2016 3:33 AM by Obi-wan Kenobi
    paragraph rules
    Suzan.V Level 1
      Hi all,
      kindly i'm asking about who to reverse " paragraph rules" values for (Right/Left indent) as shown:
      for ex, Left indent = 1 and Right indent = 3 then after script be reversed Left = 3 and Right = 1 and i hope that go through all paragraph styles and non styles text too
      with Rule above or below
      any hint please
      Cheers
      Suzan
        • 1. Re: paragraph rules
          Obi-wan Kenobi Level 5
          Hi Suzan,
          You could work a little with this:
          ruleAboveLeftIndent
          ruleAboveRightIndent
          ruleBelowLeftIndent
          ruleBelowRightIndent
          See:  InDesign ExtendScript API (11.0)
          • 2. Re: paragraph rules
            Suzan.V Level 1
            Hi Obi,
            Thanks for your reply, i will try to find it out using your hint and i hope i get it fast, if don't i will be grateful to back to you again
            Cheers
            Suzan
            • 3. Re: paragraph rules
              Suzan.V Level 1
              many thanks to you Obi my dear, i did it and worked well
              Best Regards
              Suzan
              • 4. Re: paragraph rules
                Something simply like this:
                myParas = app.activeDocument.stories.everyItem().paragraphs.everyItem().getElements();
                for (P = 0; P < myParas.length; P++)
                    var AL = myParas[P].ruleAboveLeftIndent;
                    var AR = myParas[P].ruleAboveRightIndent;
                    var BL = myParas[P].ruleBelowLeftIndent;
                    var BR = myParas[P].ruleBelowRightIndent;
                    myParas[P].ruleAboveLeftIndent = AR;
                    myParas[P].ruleAboveRightIndent = AL;
                    myParas[P].ruleBelowLeftIndent = BR;
                    myParas[P].ruleBelowRightIndent = BL;
                • 5. Re: paragraph rules
                  Suzan.V Level 1
                  Hi Obi,
                  well i tried your code but nothing changed for each right and left indent and i see that your code make my paragraph styles seems to be override !!
                  i wrote this code and seems working well for me, you can check too
                  var myPStyle = myDoc.allParagraphStyles;
                  for(i=1; i<myPStyle.length; i++){
                       var  ruleAboveRightIndentVal = myPStyle[i].ruleAboveRightIndent;
                       myPStyle[i].ruleAboveRightIndent = myPStyle[i].ruleAboveLeftIndent;
                        myPStyle[i].ruleAboveLeftIndent =ruleAboveRightIndentVal;
                          var  ruleBelowRightIndentVal = myPStyle[i].ruleBelowRightIndent;
                       myPStyle[i].ruleBelowRightIndent = myPStyle[i].ruleBelowLeftIndent;
                        myPStyle[i].ruleBelowLeftIndent =ruleBelowRightIndentVal;
                  Suzan
                  • 6. Re: paragraph rules
                    Suzan,
                    Alas, not so simple!
                    Here, 4 paras: in black color, "standard" para style (no para rules in settings) but manually done ; in red color, a para style with para rules in settings, "pure" in the first para, manually modified in the second one.
                    1/ Before scripts:
                    2/ After mine, the 4 paras have been treated, but overridden:
                    3/ With yours, "black" paras no treated, first "red" para = "pure" para style ( the style has been correctly updated), second "red" para: no correct result:
