If I export a file (DNG to JPEG with all metadata) and then end up re-importing that file, it's not caught by "Don't import suspected duplicates". I think it should be. Can it be?
Exporting a DNG file to a JPG file, whether or not you included all the metadata, makes a New File so the Don't import dups doesn't apply.
The DNG is one file and the JPG another. Doesn't matter what the content of the image is or the metadata. Two completely different files with different file extensions.
On a technical level, you are correct - you're assuming the setting actually means "don't import suspected duplicate files".
On a functional level, however, I'd rather than the setting mean "don't import suspected duplicate photos". This is both technically possible and more useful.
Not really. On all levels I am correct.
A duplicate file is a file with the same name and extension. If you tried to Re-Import the original DNG file, like maybe you copied it to another folder on purpose or by accident, then the Don't Import Suspected Duplicates would apply.
When I export RAW files to JPG I want them in the catalog. In fact I have it set to "Included in this Catalog" and "Stack with Original" checked for just that reason. If I didn't I wouldn't know which files I had exported. I also have it set to import any file I send to PS.
With your thinking none of them would ever get imported into the LR catalog file and that goes against how LR is intended to work.
All images in one database system.
Clearly the way it works now is best for you.
Also, clearly, it would be better for my workflow if it worked differentry.
Lightroom absolutely has the potential to satisfy both requirements, even if my workflow offends your sensibilities.
