I am using Adobe Acrobat XI Pro. I am trying to create a stamp with a white background. For some reason, every stamp I create has a transparent background.
I type the text in either MS Word or WordPerfect and save as a PDF.
In Acrobat, I crop the PDF to the include only the text I was as the stamp. Then, in Acrobat, I click "Custom Stamps," "Create Custom Stamps," and select the PDF file I saved above. When I use the stamp, it has a transparent background.
In the past, the background was white and I had to take extra steps to make a stamp with a transparent background.
Did something change? Am I doing something wrong? This used to be really easy, and now I am at a loss. I have tried on both my office and home computer with the same results.
Thank you in advance for any help. This is my first post, I apologize if I picked the wrong forum. I tried unsuccessfully to find the answer in either the forum or in general with Google. All my search results show how to create a transparent stamp.
I think this is due to a change in MS Word - I don't know about WordPerfect, it's been decades since I last used that application. Word used to always add a white background to any PDF file you created from a Word document. When I just tried this, there was no longer a white background. You are correct, in the past, there was always an additional step to remove that background. The good news is, that' no longer necessary However, if you want to have a non-transparent stamp, you now have to add
...Copy link to clipboard
I think this is due to a change in MS Word - I don't know about WordPerfect, it's been decades since I last used that application. Word used to always add a white background to any PDF file you created from a Word document. When I just tried this, there was no longer a white background. You are correct, in the past, there was always an additional step to remove that background. The good news is, that' no longer necessary However, if you want to have a non-transparent stamp, you now have to add an additional step to your process.
Here is how I would approach this: You need to create a text box in MS Word, and then specify a white background color for that text box. Once converted to PDF, that background color will be behind the text. When you now create a stamp from that PDF file, that background will obscure anything in your document that the stamp is place on top of.
Thank you for the explanation.
