Hello, I used to have Premiere Pro CC. I capture gameplay at 1440p, 60fps, 50mbps bitrate, and on Premiere Pro CC it was possible to render with those same settings or even a higher bitrate, in mp4 h.264 I believe. Is this possible in Premiere Elements 15, or would I need to get Premiere Pro CC again? The 1440p isnt a dealbreaker, If it could do 1080p, 60fps at at least 50mbps I would still be interested. I know a lot of folks think thats way too high of a bitrate but you can really see the difference on YouTube. Thanks!
The max you can output an 1440p60 MP4 as in Premiere Elements is 30 mbps.
I would avoid resolutions that give you a PAR other then 1.0.
You can go up to 300 if tweaking the advanced settings.
