2 Replies Latest reply on Nov 17, 2016 11:25 AM by salvatoreb86349831
    Problem phonegap build Android app
    salvatoreb86349831 Level 1
      Help me with this error please, ID App 2345144
      tahks a lot.
      Build Date: 2016-11-17 14:32:00 +0000
      Configuration on demand is an incubating feature.
      Incremental java compilation is an incubating feature.
      :preBuild UP-TO-DATE
      :preReleaseBuild UP-TO-DATE
      :checkReleaseManifest
      :preDebugBuild UP-TO-DATE
      :CordovaLib:preBuild UP-TO-DATE
      :CordovaLib:preDebugBuild UP-TO-DATE
      :CordovaLib:compileDebugNdk UP-TO-DATE
      :CordovaLib:compileLint
      :CordovaLib:copyDebugLint UP-TO-DATE
      :CordovaLib:mergeDebugProguardFiles
      :CordovaLib:packageDebugRenderscript UP-TO-DATE
      :CordovaLib:checkDebugManifest
      :CordovaLib:prepareDebugDependencies
      :CordovaLib:compileDebugRenderscript
      :CordovaLib:generateDebugResValues
      :CordovaLib:generateDebugResources
      :CordovaLib:packageDebugResources
      :CordovaLib:compileDebugAidl
      :CordovaLib:generateDebugBuildConfig
      :CordovaLib:mergeDebugShaders
      :CordovaLib:compileDebugShaders
      :CordovaLib:generateDebugAssets
      :CordovaLib:mergeDebugAssets
      :CordovaLib:processDebugManifest
      :CordovaLib:processDebugResources
      :CordovaLib:generateDebugSources
      :CordovaLib:incrementalDebugJavaCompilationSafeguard
      :CordovaLib:compileDebugJavaWithJavac
      :CordovaLib:compileDebugJavaWithJavac - is not incremental (e.g. outputs have changed, no previous execution, etc.).
      Note: Some input files use or override a deprecated API.
      Note: Recompile with -Xlint:deprecation for details.
      :CordovaLib:processDebugJavaRes UP-TO-DATE
      :CordovaLib:transformResourcesWithMergeJavaResForDebug
      :CordovaLib:transformClassesAndResourcesWithSyncLibJarsForDebug
      :CordovaLib:mergeDebugJniLibFolders
      :CordovaLib:transformNative_libsWithMergeJniLibsForDebug
      :CordovaLib:transformNative_libsWithSyncJniLibsForDebug
      :CordovaLib:bundleDebug
      :CordovaLib:preReleaseBuild UP-TO-DATE
      :CordovaLib:compileReleaseNdk UP-TO-DATE
      :CordovaLib:copyReleaseLint UP-TO-DATE
      :CordovaLib:mergeReleaseProguardFiles
      :CordovaLib:packageReleaseRenderscript UP-TO-DATE
      :CordovaLib:checkReleaseManifest
      :CordovaLib:prepareReleaseDependencies
      :CordovaLib:compileReleaseRenderscript
      :CordovaLib:generateReleaseResValues
      :CordovaLib:generateReleaseResources
      :CordovaLib:packageReleaseResources
      :CordovaLib:compileReleaseAidl
      :CordovaLib:generateReleaseBuildConfig
      :CordovaLib:mergeReleaseShaders
      :CordovaLib:compileReleaseShaders
      :CordovaLib:generateReleaseAssets
      :CordovaLib:mergeReleaseAssets
      :CordovaLib:processReleaseManifest
      :CordovaLib:processReleaseResources
      :CordovaLib:generateReleaseSources
      :CordovaLib:incrementalReleaseJavaCompilationSafeguard
      :CordovaLib:compileReleaseJavaWithJavac
      :CordovaLib:compileReleaseJavaWithJavac - is not incremental (e.g. outputs have changed, no previous execution, etc.).
      :CordovaLib:processReleaseJavaRes UP-TO-DATE
      :CordovaLib:transformResourcesWithMergeJavaResForRelease
      :CordovaLib:transformClassesAndResourcesWithSyncLibJarsForRelease
      :CordovaLib:mergeReleaseJniLibFolders
      :CordovaLib:transformNative_libsWithMergeJniLibsForRelease
      :CordovaLib:transformNative_libsWithSyncJniLibsForRelease
      :CordovaLib:bundleRelease
      :prepareComAndroidSupportAnimatedVectorDrawable2500Library
      :prepareComAndroidSupportAppcompatV72500Library
      :prepareComAndroidSupportSupportCompat2500Library
      :prepareComAndroidSupportSupportCoreUi2500Library
      :prepareComAndroidSupportSupportCoreUtils2500Library
      :prepareComAndroidSupportSupportFragment2500Library
      :prepareComAndroidSupportSupportMediaCompat2500Library
      :prepareComAndroidSupportSupportV42500Library
      :prepareComAndroidSupportSupportVectorDrawable2500Library
      :prepareComGoogleAndroidGmsPlayServicesBase980Library
      :prepareComGoogleAndroidGmsPlayServicesBasement980Library
      :prepareComGoogleAndroidGmsPlayServicesGcm980Library
      :prepareComGoogleAndroidGmsPlayServicesIid980Library
      :prepareComGoogleAndroidGmsPlayServicesLocation980Library
      :prepareComGoogleAndroidGmsPlayServicesTasks980Library
      :prepareProjectCordovaLibUnspecifiedReleaseLibrary
      :compileReleaseAidl
      :mergeReleaseAssets
      :mergeReleaseResources
      /project/AndroidManifest.xml:70:5-80 Warning:
      Element uses-permission#android.permission.ACCESS_COARSE_LOCATION at AndroidManifest.xml:70:5-80 duplicated with element declared at AndroidManifest.xml:54:5-80
      /project/AndroidManifest.xml:71:5-78 Warning:
      Element uses-permission#android.permission.ACCESS_FINE_LOCATION at AndroidManifest.xml:71:5-78 duplicated with element declared at AndroidManifest.xml:55:5-78
      /project/AndroidManifest.xml:72:5-88 Warning:
      Element uses-permission#android.permission.ACCESS_LOCATION_EXTRA_COMMANDS at AndroidManifest.xml:72:5-88 duplicated with element declared at AndroidManifest.xml:56:5-88
      /project/AndroidManifest.xml:73:5-74 Warning:
      Element uses-permission#android.permission.READ_PHONE_STATE at AndroidManifest.xml:73:5-74 duplicated with element declared at AndroidManifest.xml:65:5-74
      /project/AndroidManifest.xml:74:5-78 Warning:
      Element uses-permission#android.permission.ACCESS_NETWORK_STATE at AndroidManifest.xml:74:5-78 duplicated with element declared at AndroidManifest.xml:5:5-78
      :processReleaseResources/project/res/xml/authenticator.xml:5:19-31: AAPT: No resource found that matches the given name (at 'icon' with value '@mipmap/icon').
      /project/res/xml/authenticator.xml:6:24-36: AAPT: No resource found that matches the given name (at 'smallIcon' with value '@mipmap/icon').
      FAILED
      FAILURE: Build failed with an exception.
      * What went wrong:
      Execution failed for task ':processReleaseResources'.
      > com.android.ide.common.process.ProcessException: org.gradle.process.internal.ExecException: Process 'command '/android-sdk/build-tools/24.0.1/aapt'' finished with non-zero exit value 1
      * Try:
      Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output.
      BUILD FAILED
      Total time: 5.789 secs
      Error: /project/gradlew: Command failed with exit code 1 Error output:
      * What went wrong:
      * Try:
        at ChildProcess.whenDone (/project/cordova/node_modules/cordova-common/src/superspawn.js:169:23)
        at emitTwo (events.js:106:13)
        at ChildProcess.emit (events.js:191:7)
        at maybeClose (internal/child_process.js:877:16)
        at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
