1 Reply Latest reply on Nov 17, 2016 10:22 AM by JimHess
    Print Paper Plugins
    brendenp95619359 Level 1
      Hi All,
      I'm fairly new to LR and I was just wondering if there is a way to increase the size of the paper when you are in the "print module" or is there a way that you can customize a special size or last of all is there a plugin / preset that I can download ???
      Thank you in advance
      Brenden P
        • 1. Re: Print Paper Plugins
          It is possible to increase the size to any size that your printer will support. This is controlled through the page setup button in the lower left-hand corner of the print dialog. That button will call your printer driver where you can specify the size and type of paper you are going to use. That selection will then be reflected in the Lightroom print dialog interface.
