10 Replies Latest reply on Dec 1, 2016 12:37 PM by johnrellis
    Group Into Stacks
    EastTexas44
      I'm running Lightroom 6.7 (not CC) on an iMac using Sierra and can't group selected images into stacks while in Library module.  Cmd + G isn't working either.  This action stopped working before updating to 6.7.  Suggestions?
        • 1. Re: Group Into Stacks
          Just Shoot Me Adobe Community Professional
          What error message do you get?
          Are the images in the same folder?
          • 2. Re: Group Into Stacks
            EastTexas44 Level 1
            I don't get any error message; nothing happens.  Yes, they're in the same folder.  Thanks for replying.
            • 3. Re: Group Into Stacks
              johnrellis Most Valuable Participant
              Try stacking with the menu command Photo > Stacking > Group Into Stack. If that works, then that indicates the problem is with the keyboard shortcut.
              (Should I assume from your user name that you're running LR in English?  There have recently been problems with keyboard shortcuts in other languages.)
              • 4. Re: Group Into Stacks
                john beardsworth Adobe Community Professional & MVP
                Are you in a folder or in a dumb collection when you try Cmd G? You're not in a smart collection?
                • 5. Re: Group Into Stacks
                  EastTexas44 Level 1
                  John:  I tried Photo>Stacking>Group into Stacks and had the same problem.  Yes, I'm running in English.
                  • 6. Re: Group Into Stacks
                    EastTexas44 Level 1
                    John:  I'm in a regular folder--not a collection or smart collection.
                    • 7. Re: Group Into Stacks
                      At this point, I only have two suggestions:
                      1. Try resetting LR's preferences: http://www.lightroomforums.net/showthread.php?25197-Resetting-the-lightroom-preferences-fi le-updated That often fixes things when LR goes wonky (though I'm not so sure about your situation).  But it's quick and easy to try.
                      2. If that doesn' help, post a full-resolution screenshot of your entire LR window, with the photos you're trying to stack selected.  Maybe we'll see something we're all missing.
                      • 8. Re: Group Into Stacks
                        EastTexas44 Level 1
                        John:  I've been out of town.  I'll give your suggestions a try tonight or tomorrow and will do as your requested if it works.  Thank you.
                        • 9. Re: Group Into Stacks
                          EastTexas44 Level 1
                          John:  Please skip to the last paragraph.
                          I'm trying the reset the LR preferences file.  However, as you can see from these three screenshots, I can't locate this file.
                          Top left screenshot is the path that the instructions say to follow, but it doesn't lead to a Library folder.
                          So, I tried getting there two other way, as shown on the next two screenshots, but they didn't work either.
                          BTW, when I installed LR I let it put folders/files where it wanted--I didn't specify any user-defined locations.  Also I began having the problem of Grouping into Stacks not working a couple weeks ago when I was still using LR 6.0.  That's when I decided to upgrade to LR 6.7.
                          I just went into LR to make a screenshot showing grouping of 4 images into a stack and it worked!  So I tried it with several other folders of images, as they also worked.   Why now, I have no idea.  LR apparently performs self fixes when it sees its user trying (but failing) to reset preferences.     I guess I'll just post something like "Problem resolved itself" on the forum--unless you have a better idea.
                          Thanks for trying to help.
                          • 10. Re: Group Into Stacks
                            Sometimes simply restarting LR, or rebooting your computer, can fix intermittent problems.
                            I think you were looking at reset instructions for earlier versions of LR.  LR 6 lets you hold down a couple of keys when you start it -- you don't need to find any system files; see the section "Resetting the Preferences File – Lightroom 6/CC only": http://www.lightroomforums.net/showthread.php?25197-Resetting-the-lightroom-preferences-fi le-updated
