3 Replies Latest reply on Nov 20, 2016 3:11 AM by JR_Boulay
    util.printf()
    JR_Boulay Adobe Community Professional
      Hi.
      I know how to use util.printf() to get a number formated as: 1234.56
      n = util.printf("%.2f", n);
      What I need is a number formated as: 1234,56
      With a comma instead of a dot.
      How can I do that?
      Where can I find some infos since I cannot find nothing in the JS Reference?
      Thank you.
        • 1. Re: util.printf()
          I would add the "nDec" parameter with a value of ",2".
          var nValue = 123.56;
          var nDec = ",2";
          var cFlags = "";
          var nWidth = "";
          var nPrecision = ".2";
          var cConvChar = "f";
          var cFormat = "%" + nDec + cFlags + nWidth + nPrecision + cConvChar;
          console.println("cFormat: " + cFormat);
          var cValue = util.printf(cFormat, nValue);
          console.println("nDec " + nDec + " — Period separated, comma decimal point : " + cValue);
          It is explained under the "util" object and the "printf" method.
          • 2. Re: util.printf()
            Great great great, it works fine.
            In fact, the French format is closest if the "nDec" parameter have a value of ",3".
            Thank you very much, I learned something today.
            • 3. Re: util.printf()
              It is close but not satisfactory since French format requires blank spaces as separators:
              10 234 567 890,55
              Since French separators are not available directly as a format I use a "dot separators" format, and I replace dots by blank spaces:
              n = util.printf("%,2.2f",n).toString().replace(/\./gim," ");
              And the goal is reached!
              Thank you once again.
              En français :
              Le format de nombre français n'étant pas disponible directement dans les formats, la ruse dans la formule ci-dessus consiste à utiliser un format qui place des points comme séparateurs de milliers, et à remplacer à la volée les points par des espaces.
