hi, when i want to open lightroom, i get the following message: (i will translate it under the png )
translation :
the lightroom-catalog "lightroom catalog", can not be opened because it is already opened in another application.
--close the other copy of lightroom before you start the application --
the tabs are : chose other catalog - continue - close
I cant find the solution!! Help!!
When Lightroom is running, there is a lock file present next to the catalog file to prevent other users from opening the catalog.
The lock file is normally deleted when you close LR, but if it isn't closed properly (power failure or crash), the lock file may not be deleted, preventing you from opening Lightroom.
To fix this, use the File exlorer and go to the folder containing the catalog, usually inside the Pictures or My Pictures folder.
Delete the file Lightroom Catalog.lrcat.lock - do not delet
...Copy link to clipboard
Delete the file Lightroom Catalog.lrcat.lock - do not delete anything else.
Now launch Lightroom.
Hi there,
Wow, it worked!! I'm very thankfull!!
Kind regards,
Yves
Op zo 20 nov. 2016 om 10:24 schreef Per Berntsen <forums_noreply@adobe.com>
can t open lightroom anymore created by Per Berntsen
<https://forums.adobe.com/people/Per+Berntsen> in Photoshop Lightroom - View
the full discussion <https://forums.adobe.com/message/9149803#9149803>
Thanks ! Had the same problem for wa while now.
