20 Replies Latest reply on Jan 30, 2009 10:57 AM by Nigel Pegg
    Problem with examples
    Matt Newell
      I just download the project and if I try to compile and debug any of the examples I get this error.
      insufficient permissions to create node
      This happens on messaging_internal function createNode(p_collectionName:String, p_nodeName:String=null, p_nodeConfiguration:NodeConfiguration=null):void
      Any ideals? Also I am having a hard time find information on Cocomo. Will Adobe post Cocomo on livedocs?
        • 1. Re: Problem with examples
          Hironmay Level 4
          In any of the example, you need to add your userName i.e. your email id , your password and your roomUrl.
          All these values you need to add yourselves in the example files to run the examples.
          Cocomo livedocs are here :
          http://livedocs.adobe.com/labs/acrobatcom/index.html
          Hironmay Basu
          • 2. Re: Problem with examples
            Matt Newell Level 1
            I did add my dev account info. I thought it might have to do with using flash 10 vvs flash 9 but that is not the case.
            You can see in my output I get passed the user auth
            Cocomo Beta Build # : 0.9
            requestInfo http://connect.acrobat.com/myURL?mode=xml&x=0.6824287408962846
            getMeetingInfo: status=0
            Getting FMS at https://na2.connectnow.acrobat.com/fms?ticket=1wwsjhsfbiead, attempt #1/3
            result: <fms>
            <origin>fms2.acrobat.com</origin>
            <proto_ports>rtmps:443</proto_ports>
            <retry_attempts>2</retry_attempts>
            </fms>
            #FMSConnector# Thu Nov 20 13:55:07 GMT-0500 2008 protocols: [object ProtocolPortPair]
            #FMSConnector# Thu Nov 20 13:55:07 GMT-0500 2008 [attempt 1 of 2] Connecting to 0/0: rtmps://fms2.acrobat.com/cocomo/na2-d19cb600-1059-45ba-b5aa-1530585b3084/mymeeting #startProtosConnect#
            #FMSConnector# Thu Nov 20 13:55:07 GMT-0500 2008 tempNetStatusHandler 0/1,NetConnection.Connect.Success
            #FMSConnector# Thu Nov 20 13:55:07 GMT-0500 2008 isTunneling? false
            #FMSConnector# Thu Nov 20 13:55:07 GMT-0500 2008 is using RTMPS? true
            RECEIVED LOGIN AT SESSION
            .user descriptor from server [object]
            .affiliation [number]= 5
            .displayName [string]= myDevAccount
            .role [number]= 5
            .userID [string]= GUEST-AB4670FA-3D3E-4E13-9141-6DA5C830E847
            RECEIVENODES UserManager
            receiveAllSynchData UserManager
            checkManagerSync:[object UserManager]
            RECEIVENODES FileManager
            receiveAllSynchData FileManager
            checkManagerSync:[object FileManager]
            RECEIVENODES AVManager
            receiveAllSynchData AVManager
            checkManagerSync:[object StreamManager]
            RECEIVENODES RoomManager
            receiveAllSynchData RoomManager
            checkManagerSync:[object RoomManager]
            • 3. Re: Problem with examples
              Hironmay Level 4
              Are you sure you are entering as owner in your application after the first time you created the room? You are getting permission errors since you can see in your logs your affiliation and role is 5 i.e. lower than guest. You need first time to go into your application with a newly created room as the owner.
              The first time you run the code, the whiteboard, note, etc, are trying to create new shared destinations on the service. Since we only want developers to be able to add new features to their room, the first time you run an application, you should log in with your developer account - this installs those shared components within your room. From then on, your (autopromoted) guest users can use them.
              Like for e.g. in DefaultPods example in DefaultPods.mxml you should have for the first time
              <rtc:AdobeHSAuthenticator
              id="auth"
              userName="AdobeIDusername" // here put you email address
              password="AdobeIDpassword" /> // here put your password
              <rtc:ConnectSessionContainer
              roomURL="YourPersonalRoomUrl" // roomURL of format: http://connectnow.acrobat.com/<account>/<roomname>.
              id="cSession"
              authenticator="{auth}">
              Hope this helps.
              Hironmay Basu
              • 4. Re: Problem with examples
                Matt Newell Level 1
                I get this error using the login example. When I login I use my dev account with my acrobat url. I don't understand how I would set myselft to owner.
                • 5. Re: Problem with examples
                  Hironmay Level 4
                  Hi ,
                  In the login example, after you put down your dev account url , user name and password , are you clicking on radiobutton user ( by default guest is selected ). You have to log in as user.
                  Hironmay Basu
                  • 6. Re: Problem with examples
                    Nigel Pegg Level 4
                    Hi Matt,
                    Chances are, you logged in as a guest first, and your session credentials got cached in the browser. Try clearing your sessions or restarting your browser, and you'll be able to log in as the OWNER.
                    hope that helps
                    • 7. Re: Problem with examples
                      Matt Newell Level 1
                      Nope clearing the browser or restarting does not fix the problem.
                      So just to clarify what I am trying to do.
                      Using the login example
                      type in my url for my meeting room
                      type my dev username
                      type my dev password
                      select the user radio button not the guest
                      login
                      With this being said I can login with the CocomoDevConsole and edit my room.
                      • 8. Re: Problem with examples
                        Hironmay Level 4
                        In the cocomo dev console when you log in, in the url you put
                        whereas if you are using roomURL you should be using
                        Are you doing this ?
                        Hironmay basu
                        • 9. Re: Problem with examples
                          Matt Newell Level 1
                          Yes, the login example even comes back and says the user password is authenticated to the url and then it stalls for a sec and then it bombs with the permissions issue.
                          • 10. Re: Problem with examples
                            Hironmay Level 4
                            Are you able to run any other example like DefaultPods by adding your same details of roolURL, userName and password ?
                            Hironmay Basu
                            • 11. Re: Problem with examples
                              Nigel Pegg Level 4
                              Hi Matt,
                              Could you copy-paste your debug output for us again? The output you've posted so far clearly shows you coming in as a guest (role=5).
                              • 12. Re: Problem with examples
                                jgcrilly
                                Hey guys, i'm having the same problem. I've gone through all the required steps (username, password, restarted the browser, restarted the system (i'm on a mac OS X), tried the SimpleChatExample, DefaultPods, LoginDialog and the example in the video, all with the same output:
                                requestInfo http://connectnow.acrobat.com/jaydub17/awesomeroom?mode=xml&x=0.6546507026068866
                                Getting FMS at https://na2.connectnow.acrobat.com/fms?ticket=1ufwu6a78ljwg, attempt #1/3
                                result: <fms>
                                </fms>
                                #FMSConnector# Thu Nov 20 18:06:00 GMT-0800 2008 protocols: [object ProtocolPortPair]
                                #FMSConnector# Thu Nov 20 18:06:00 GMT-0800 2008 [attempt 1 of 2] Connecting to 0/0: rtmps://fms2.acrobat.com/cocomo/na2-sdk-a5e1baa1-4c14-44f4-b3c3-8261a0787936/awesomeroom #startProtosConnect#
                                #FMSConnector# Thu Nov 20 18:06:01 GMT-0800 2008 tempNetStatusHandler 0/1,NetConnection.Connect.Success
                                #FMSConnector# Thu Nov 20 18:06:01 GMT-0800 2008 isTunneling? false
                                #FMSConnector# Thu Nov 20 18:06:01 GMT-0800 2008 is using RTMPS? true
                                .displayName [string]= null
                                .role [number]= 10
                                .userID [string]= GUEST-35D49C2F-C7AE-484A-9616-51DC91CC1858
                                Error: Error - insufficient permissions to create a new CollectionNode
                                at com.adobe.rtc.messaging.manager::MessageManager/ http://www.adobe.com/2006/connect/cocomo/messaging/internal::subscribeCollection()[/Users/ jcrilly/Applications/Adobe Flex Builder 3/plugins/com.adobe.cocomo/src/com/adobe/rtc/messaging/manager/MessageManager.as:190]
                                thanks guys!
                                • 13. Re: Problem with examples
                                  Matt Newell Level 1
                                  Nigel Pegg you are correct I am logged in at role=5, but I don't know how I can type my dev account different?
                                  I think it has something to do with "warning: unable to bind to property 'userManager' on class 'com.adobe.rtc.session::ConnectSessionContainer'"
                                  [SWF] Users:mattnewell:Documents:Flex Builder 3:Cocomo:bin-debug:Cocomo.swf - 1,255,563 bytes after decompression
                                  requestInfo http://connectnow.acrobat.com/mattnewell/mymeeting?mode=xml&x=0.4138511186465621
                                  Getting FMS at https://na2.connectnow.acrobat.com/fms?ticket=1qpanwdxbm1w2, attempt #1/3
                                  result: <fms>
                                  <origin>fms1.acrobat.com</origin>
                                  </fms>
                                  #FMSConnector# Thu Nov 20 21:04:48 GMT-0500 2008 protocols: [object ProtocolPortPair]
                                  #FMSConnector# Thu Nov 20 21:04:48 GMT-0500 2008 [attempt 1 of 2] Connecting to 0/0: rtmps://fms1.acrobat.com/cocomo/na2-d19cb600-1059-45ba-b5aa-1530585b3084/mymeeting #startProtosConnect#
                                  #FMSConnector# Thu Nov 20 21:04:54 GMT-0500 2008 tempNetStatusHandler 0/1,NetConnection.Connect.Success
                                  #FMSConnector# Thu Nov 20 21:04:54 GMT-0500 2008 isTunneling? false
                                  #FMSConnector# Thu Nov 20 21:04:54 GMT-0500 2008 is using RTMPS? true
                                  .displayName [string]= Matt Newell
                                  .role [number]= 5
                                  .userID [string]= WCD-0383665F4921FE99992015C2
                                  at com.adobe.rtc.messaging.manager::MessageManager/ http://www.adobe.com/2006/connect/cocomo/messaging/internal::subscribeCollection()[C:\work \main\connect\cocomo\src\com\adobe\rtc\messaging\manager\MessageManager.as:190
                                  at com.adobe.rtc.sharedModel::CollectionNode/subscribe()[C:\work\main\connect\cocomo\src\com \adobe\rtc\sharedModel\CollectionNode.as:327]
                                  at com.adobe.rtc.pods.cameraClasses::CameraModel/subscribe()[C:\work\main\connect\cocomo\src \com\adobe\rtc\pods\cameraClasses\CameraModel.as:165]
                                  at com.adobe.rtc.pods::WebCamera/subscribe()[C:\work\main\connect\cocomo\src\com\adobe\rtc\p ods\WebCamera.as:903]
                                  at com.adobe.rtc.pods::WebCamera/createChildren()[C:\work\main\connect\cocomo\src\com\adobe\ rtc\pods\WebCamera.as:803]
                                  at mx.core::UIComponent/initialize()[E:\dev\3.0.x\frameworks\projects\framework\src\mx\core\ UIComponent.as:5262]
                                  at mx.core::UIComponent/ http://www.adobe.com/2006/flex/mx/internal::childAdded()[E:\dev\3.0.x\frameworks\projects\ framework\src\mx\core\UIComponent.as:5159
                                  at mx.core::Container/ http://www.adobe.com/2006/flex/mx/internal::childAdded()[E:\dev\3.0.x\frameworks\projects\ framework\src\mx\core\Container.as:3297
                                  at mx.core::Container/addChildAt()[E:\dev\3.0.x\frameworks\projects\framework\src\mx\core\Co ntainer.as:2210]
                                  at mx.core::Container/addChild()[E:\dev\3.0.x\frameworks\projects\framework\src\mx\core\Cont ainer.as:2140]
                                  at mx.core::Container/createComponentFromDescriptor()[E:\dev\3.0.x\frameworks\projects\frame work\src\mx\core\Container.as:3673]
                                  at mx.core::Container/createComponentsFromDescriptors()[E:\dev\3.0.x\frameworks\projects\fra mework\src\mx\core\Container.as:3485]
                                  at mx.containers::Panel/createComponentsFromDescriptors()[E:\dev\3.0.x\frameworks\projects\f ramework\src\mx\containers\Panel.as:1526]
                                  at mx.core::Container/createChildren()[E:\dev\3.0.x\frameworks\projects\framework\src\mx\cor e\Container.as:2587]
                                  at mx.containers::Panel/createChildren()[E:\dev\3.0.x\frameworks\projects\framework\src\mx\c ontainers\Panel.as:1054]
                                  at mx.core::Container/initialize()[E:\dev\3.0.x\frameworks\projects\framework\src\mx\core\Co ntainer.as:2524]
                                  at com.adobe.rtc.session::ConnectSessionContainer/buildChild()[C:\work\main\connect\cocomo\s rc\com\adobe\rtc\session\ConnectSessionContainer.as:237]
                                  at com.adobe.rtc.session::ConnectSessionContainer/onSynchronizationChange()[C:\work\main\con nect\cocomo\src\com\adobe\rtc\session\ConnectSessionContainer.as:277]
                                  at flash.events::EventDispatcher/dispatchEventFunction()
                                  at flash.events::EventDispatcher/dispatchEvent()
                                  at com.adobe.rtc.session::ConnectSession/checkManagerSync()[C:\work\main\connect\cocomo\src\ com\adobe\rtc\session\ConnectSession.as:481]
                                  at com.adobe.rtc.sharedManagers::RoomManager/onSynchronizationChange()[C:\work\main\connect\ cocomo\src\com\adobe\rtc\sharedManagers\RoomManager.as:1076]
                                  at com.adobe.rtc.sharedModel::CollectionNode/ http://www.adobe.com/2006/connect/cocomo/messaging/internal::setIsSynchronized()[C:\work\m ain\connect\cocomo\src\com\adobe\rtc\sharedModel\CollectionNode.as:664
                                  at com.adobe.rtc.messaging.manager::MessageManager/receiveAllSynchData()[C:\work\main\connec t\cocomo\src\com\adobe\rtc\messaging\manager\MessageManager.as:783]
                                  at com.adobe.rtc.messaging.manager::MessageManager/ http://www.adobe.com/2006/connect/cocomo/messaging/internal::receiveItems()[C:\work\main\c onnect\cocomo\src\com\adobe\rtc\messaging\manager\MessageManager.as:539
                                  at com.adobe.rtc.session.managers::SessionManagerBase/receiveItems()[C:\work\main\connect\co como\src\com\adobe\rtc\session\managers\SessionManagerBase.as:374]
                                  • 14. Re: Problem with examples
                                    Raff. Adobe Employee
                                    Matt,
                                    the warning you see "warning: unable to bind to property 'userManager' on class 'com.adobe.rtc.session::ConnectSessionContainer'" is not related to your problem and it's really harmless.
                                    Your problem is that this user:
                                    .role [number]= 5
                                    is not the owner of the account, and the account you are using is a ConnectNow account (note how you are trying to access the room "mymeeting" that is the default and only room in a meeting account).
                                    I suspect you have two different AdobeID, with 2 email addresses, one of which may be associated to an SDK account but you are using it to access a meeting account
                                    jgcrilly, your problem is different. These are the info about the user that Cocomo sees:
                                    .role [number]= 10
                                    note that displayName is null and the userID is GUEST-*
                                    Looks like you are not passing anything to the authenticator, or for some reason we manage to lose all your info :)
                                    A snipped of the code you are using (setting the info in the authenticator) would help.
                                    • 15. Re: Problem with examples
                                      Matt Newell Level 1
                                      Yes I do have two diffrent AdobeID's one I use on forms and one I created for the Cocomo SDK. The login for the SDK works on the CocomoDev AIR app and this is what I am using to login in the examples.
                                      Should I use my AdobeID that is not associated with the SDK.
                                      One thing to note when I set up my Coocomo account I misspelled my email address so I had to edit it, but when I tried it said another AdobeID uses this email so I used a second email address for the dev account. It seems the update of my account info did not complete take.
                                      • 16. Re: Problem with examples
                                        Ashford_S._C.
                                        Hey guys, I seem to be getting the same error as well, would you be able to analyze mine too. I'm lost. Once i pass the error, I get the chat screen but cannot send any comments to the room. Although I can see the main user.
                                        Thanks in advance!
                                        at com.adobe.rtc.messaging.manager::MessageManager/flushPendingSubscriptions()[C:\work\main\ connect\cocomo\src\com\adobe\rtc\messaging\manager\MessageManager.as:792]
                                        at com.adobe.rtc.sharedManagers::UserManager/userReceivedOrEdited()[C:\work\main\connect\coc omo\src\com\adobe\rtc\sharedManagers\UserManager.as:944]
                                        at com.adobe.rtc.sharedManagers::UserManager/onItemReceive()[C:\work\main\connect\cocomo\src \com\adobe\rtc\sharedManagers\UserManager.as:811]
                                        at com.adobe.rtc.sharedModel::CollectionNode/ http://www.adobe.com/2006/connect/cocomo/messaging/internal::receiveItem()[C:\work\main\co nnect\cocomo\src\com\adobe\rtc\sharedModel\CollectionNode.as:741
                                        at com.adobe.rtc.messaging.manager::MessageManager/ http://www.adobe.com/2006/connect/cocomo/messaging/internal::receiveItem()[C:\work\main\co nnect\cocomo\src\com\adobe\rtc\messaging\manager\MessageManager.as:661
                                        at com.adobe.rtc.session.managers::SessionManagerBase/receiveItem()[C:\work\main\connect\coc omo\src\com\adobe\rtc\session\managers\SessionManagerBase.as:331]
                                        • 17. Re: Problem with examples
                                          pdkn Level 1
                                          Hum, I'm getting problems now when trying to Authenticate with my AdobeID and password.
                                          i.e Compile an example with a guest authentication
                                          id="auth"
                                          userName="joeBlogs"
                                          > RosterList shows 'joeBlogs'
                                          now recompile with OWNER credentials:
                                          id="auth"
                                          userName="{AdobeIDEmail}"
                                          password="{AdobePassword}"
                                          Roster is still logging me is as JoeBlogs? Was working yesterday. Is there a problem with the service today? Thxs paddy ;)
                                          • 18. Re: Problem with examples
                                            Nigel Pegg Level 4
                                            @paddy, sometimes the browser holds on to session credentials and won't let go - try restarting your browser if you're switching authentication scenarios on the fly (usually, I run from FlexBuilder and it spawns a Safari window, and I never have this problem).
                                            @ashford, the problem you're encountering is that you're trying to add new features to a Cocomo room without OWNER privileges. Essentially, Cocomo only allows the account owner of a room to add new multiuser elements to a room - this is a security measure which ensures that nobody else can use your room for their own purposes. I'm going to add better info to this error so that users who encounter it will have a better sense what to do. Simply login using your developer credentials, run the room, and the new features will be added automatically, and stay there for good (so you only need to perform this step once as you develop).
                                            • 19. Re: Problem with examples
                                              pdkn Level 1
                                              Thanks Nigel, It looks like there are issues depending on weather OWNER/PUBLISHER logs in first?
                                              1: restart Browser (I'm using Firefox PC)
                                              2: Compile an example with a guest authentication first (I'm using CustomRoster)
                                              id="auth"
                                              userName="joeBlogs"
                                              Result - RosterList shows ['joeBlogs, Participant']
                                              2: recompile with OWNER credentials and open in new Firefox Tab:
                                              id="auth"
                                              Result - RosterList shows ['joeBlogs 2, Participant', 'joeBlogs, Participant']
                                              3: Recompile with a different guest authentication and open in new Firefox Tab:
                                              id="auth"
                                              userName="barbieBlogs"
                                              Result - RosterList now shows ['barbieBlogs, Participant', 'joeBlogs 2, Participant', 'joeBlogs, Participant']
                                              4: recompile with OWNER credentials and open in new Firefox Tab:
                                              Result - RosterList now shows ['barbieBlogs 2, Participant', 'barbieBlogs, Participant', 'joeBlogs 2, Participant', 'joeBlogs, Participant']
                                              5: Open in different Browser (IE7) (logging in with OWNER credentials)
                                              Result - RosterList now shows ['paddy keane, Host', 'barbieBlogs 2, Participant', 'barbieBlogs, Participant', 'joeBlogs 2, Participant', 'joeBlogs, Participant']
                                              So, as you say, looks like there is an issue with Firefox holding on to session credentials
                                              6: Now close all Browsers and restart Firefox
                                              7: recompile and login first time with OWNER credentials:
                                              id="auth"
                                              Result - RosterList now shows ['paddy keane, Host']
                                              8: re-Compile with a guest authentication
                                              id="auth"
                                              userName="joeBlogs"
                                              Result - RosterList now shows ['paddy keane, Host', 'joeBlogs, Participant']
                                              9: re-Compile with OWNER credentials:
                                              Result - RosterList now shows ['paddy keane 2, Host', 'paddy keane, Host', 'joeBlogs, Participant']
                                              10: re-Compile as guest:
                                              id="auth"
                                              Result - RosterList now shows ['paddy keane 2, Host', 'paddy keane, Host', 'barbieBlogs, Participant', 'joeBlogs, Participant']
                                              This shows session credentials working correctly
                                              Conclusion. Notice the order the users are adding in steps 1-5 and the steps 6-10. logging in first time as a guest, users are always added a index=0. But notice when logging in first as a OWNER in Steps 6-10, there seems to be priority handling, guests (PUBLISHER) are only added after OWNERS. Does that make sense? let me know if that helps to make steps 1-5 work correctly?
                                              • 20. Re: Problem with examples
                                                Nigel Pegg Level 4
                                                Hmm, very interesting Paddy - thanks for narrowing this down! We'll take a look to see if this is something we can fix on our end.
