• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
What happens when the free trial ends before I upgrade?
Contributor ,
Nov 21, 2016 Nov 21, 2016
Currently Using RoboHelp 11.0.4.291. Want to upgrade to 2015, but must use the free trial first (company policy). I have always been allowed to upgrade previous versions before the trial period ended, so I never found out what happened. Does RoboHelp revert back to RoboHelp 11 or am I forced to upgrade to 2015? I must ask because I can only recommend purchase, not make the actual purchase.
Views
541
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Nov 21, 2016 Nov 21, 2016
Depending on how you install it, you would have both RH11 & RH2015 installed – if RH2015 “expired” then you would still have 11 there; however, if you converted your RH11 projects to RH2015, there’s no going back to RH11, so this sort of “test” isn’t advised. Better to install the trial on a separate non-production machine & play with it using copies of your RH11 projects (not the real ones). Don’t make any changes to the “play” copies unless you are ok with losing the changes if you “expire”.
Votes
Translate
Translate
Community Expert ,
Votes
Translate
Translate
Report
Report
Contributor ,
Thank you Jeff!
Votes
Translate
Translate
Report
Report
LEGEND ,
LATEST
Just to note that as long as you understand the risks, there is nothing wrong with installing the eval alongside an older version. The main issues are as Jeff mentioned, don't open any existing work because you cannot revert. So make a backup copy and work with the backup.
And if you are a person that likes to double-click the XPJ to open your project in RoboHelp, because the newer version has been installed, it replaces the Windows file association so that double-clicking causes RoboHelp 2015 Release to open instead of the older version. So that may trip folks up.
As long as you only work with copies of projects and you begin by first opening RoboHelp, you should be fine using one PC.
Cheers... Rick
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
