5 Replies Latest reply on Nov 25, 2016 4:32 PM by mickyhulse
    Space before/after for placed text with hard
    mickyhulse Level 1
      What is the best way to handle placed text that looks like:
      Page: 1
      Title: This is the title
      Date: 2016
      Artist: John Doe
      Credit: John Doe
      Source: https://site.com/
      http://site.com/x
      Page: 2
      Date: 2016
      Artist: John Doe
      Credit: John Doe
      http://site.com/x
      Page: 3
      Date: 2016
      Artist: John Doe
      Credit: John Doe
      http://site.com/x
      I am placing this text into a 3-column layout master frame, so the text spans all columns and multiple pages.
      I am trying to avoid spacing issues by using "space after" (or "before").
      Unfortunately, when placed, I get this:
      I would like my text to look like this (after being placed):
      In the screen shot directly above, in order to get the related text bits to group together, I had to manually insert a "Forced Line Break" (Shift + Return) between the lines of related text.
      Note that my paragraph style, for both screenshots above, uses space after to control paragraph spacing:
      Question(s):
      Is it possible for me to place the above text and have it look like the last screen shot as seen above?
      If so, how?
      From what I can tell, other than using a tagged text file (which I would like to avoid), I'll have to do some find/replace regex work on the placed text in order to get the results I want?
      Any tips would be appreciated.
        • 1. Re: Space before/after for placed text with hard
          tpk1982 Level 4
          Is it you using only one paragraph style?
          • 2. Re: Space before/after for placed text with hard
            vinny38 Level 5
            Hi
            There are many ways to achieve what you want. This is the one I would use:
            First, make sure you don't use double line breaks nor forced-returns.
            Then, create two paragraph styles: i.e. "normal" and "1st line".
            Set up "normal" style without space after/before.
            If you want it aligned on baseline grid, make sure baseline grid leading is set to - at least - the same leading value as your paragraph style. Note: this explains why leading "looks" so big your first screenshot. Choose "View > Grids & Guides > Show/Hide Baseline Grid" for a better understanding.
            Tip: you might want to use GREP in order to set "Page:", "Title:" etc. to bold
            Then, set up "1st Line" paragraph style with a space before (any would do if aligned on baseline grid).
            Finally, use a simple search/replace in order to apply "1st line" par. style to all paragraphs including "page" text:
            Tip: Use Keep option in order to avoid "Page: x" to stand alone at the bottom of a column
            You're done.
            As I said before, this is one method, not the only one. (I don't like forced-returns, but you could also use them, using another method based on single paragraphs > Better if you want to avoid breaking)
            Hope that helps
            Regards
            • 3. Re: Space before/after for placed text with hard
              mickyhulse Level 1
              vinny38 wrote:
              Hi
              There are many ways to achieve what you want. This is the one I would use: <snip>
              Thanks so much Vinny! I really appreciate the help.
              I am trying your suggestions now and will report back my findings (looks like it's going to work pretty well).
              Thanks much!!!
              • 4. Re: Space before/after for placed text with hard
                mickyhulse Level 1
                Hi Tpk1982, thanks so much for the reply, I really appreciate the help.
                Yep, just one paragraph style so far. The bold parts are grep styles and I have the baseline grid setup.
                With that said, it looks like vinny38's suggestion will work pretty good!
                Seems like I won't be able to avoid doing a find/replace unless I head the tagged text route? Thankfully find/replace is quick, and I can save the searches to make it even easier, so I think that's going to work well for my workflow.
                Thanks again to both of you for the help!
                I'll be back soon to report my findings.
                • 5. Re: Space before/after for placed text with hard
                  mickyhulse Level 1
                  That worked really well! Thank you vinny38! I really appreciate the help!
                  The only change I made was to use Grep for the search as it ended up being much faster:
