3 Replies Latest reply on Dec 28, 2016 11:31 PM by manusia
    PhoneGap build fails with insufficient memory
    QbertMF Level 1
      Cannot get enough memory for Gradle to build an empty project :-(
      Tried vaious memory settings in the gradle.properties to no avail.
      Any ideas?
      C:\wamp\www\projects\mfeedback>cordova build android
      ANDROID_HOME=C:\Program Files\Android\android-sdk
      JAVA_HOME=C:\Program Files\Java\jdk1.8.0_111
      Subproject Path: CordovaLib
      Starting a new Gradle Daemon for this build (subsequent builds will be faster).
      FAILURE: Build failed with an exception.
      * What went wrong:
      Unable to start the daemon process.
      This problem might be caused by incorrect configuration of the daemon.
      For example, an unrecognized jvm option is used.
      Please refer to the user guide chapter on the daemon at https://docs.gradle.org/2.14.1/userguide/gradle_daemon.html
      Please read the following process output to find out more:
      Error occurred during initialization of VM
      Could not reserve enough space for 2097152KB object heap
      * Try:
      Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output.
      Error: cmd: Command failed with exit code 1 Error output:
      * What went wrong:
      * Try:
