32 Replies Latest reply on Jan 21, 2009 4:21 PM by san_flash
    Flash 8 to CS4 upgrade...files are running slow
    BrainPOP LLC Level 1
      We've just recently upgraded Flash 8 to Flash CS4. All the work that we did in flash 8 are now running slow when we try to work with the files in flash CS4.
      The files have vector symbols created in Flash 8. These are cartoon character puppets made up of solid non gradient fills. Within the main puppet are various nested symbols of head, arm, hand, and leg symbols. the problems that we experience are of following nature:
      1) files with more complex symbols on stage. delay is about 3-5 seconds.
      2) selecting and transforming objects
      3) scrubbing the timeline
      4) changing tools and saving files
      Any help would be highly appreciated.
      thanks,
      tharaka
        • 1. Re: Flash 8 to CS4 upgrade...files are running slow
          Walter Elias Level 2
          I'm having the same problem, maybe even worse than you. Same exact situation: opening cartoon character animations created in Flash 8, all flat fills. If I click on a symbol it can take up to 15 seconds before it becomes active. Double-clicking a symbol to get inside it actually causes warnings that Flash is not responding. Wait close to 30 seconds and I can then edit inside the symbol.
          Same problem changing tools. At least a 10-second delay.
          This did not happen when opening the identical Flash 8 animations in CS3.
          What, is Flash having the same horrible sluggishness problems as Photoshop CS4? I didn't think Flash relied on OpenGL.
          I have a very lean system, with no junk installed, every driver up to date, no problems with any non-CS4 apps.
          Between the absolute uselessness of Photoshop CS4 due to lag, and the sluggishness of Flash CS4 plus some minor but lethal bugs which will probably never be fixed, I'm ready to trash the whole suite.
          Only CS4 app that seems to work well for me is Dreamweaver. Funny: that was one of the two CS4 apps that was open for public beta. It was actually a real mess when they released the beta - about as messy as Flash and Photoshop are now. They got huge amounts of feedback and guess what? Dreamweaver CS4 is pretty tight.
          Maybe if all Adobe apps were open to public beta testing, rather than relying on a small group of power users (who, being advanced, tend not to use the more mundane tools the rest of us use), then they might actually fix the bugs before they release the programs.
          • 2. Re: Flash 8 to CS4 upgrade...files are running slow
            san_flash Level 2
            Hi Walter,
            Is it possible that you send us your fla? <removed by moderator>
            San
            • 3. Flash 8 to CS4 upgrade...files are running slow
              San, the smallest FLA I've tried loading is 66 MB and the largest is 102 MB. And it's an animation project under a non-disclosure agreement with the producer. I would need Adobe to also sign some NDA papers before I could release it.
              Also, before you say "Ah-ha! 66 MB! No wonder it runs slow!", note that it loads and works instantly in Flash 8 and CS3.
              • 4. Re: Flash 8 to CS4 upgrade...files are running slow
                san_flash Level 2
                Is it possible to narrow down to just the symbols that are having the problem?
                • 5. Re: Flash 8 to CS4 upgrade...files are running slow
                  hey, are you the same San guy replying to my brainpop email address? :) We can send you an FLA file if we can sign an NDA with you. can you check with your folks about NDAs?
                  thanks,
                  tharaka
                  • 6. Re: Flash 8 to CS4 upgrade...files are running slow
                    Same here. We're working on commercial animation projects and can't release anything to anybody, even Adobe engineers, without an NDA. Cheers.
                    • 7. Re: Flash 8 to CS4 upgrade...files are running slow
                      san_flash Level 2
                      Yes, I'm the same person that has been in touch with you Tharaka. I'll check on the NDA but I have a feeling it might not be possible to sign it on behalf of the company :(
                      In the mean time, we'll keep trying different animation flas we have to reproduce the problem.
                      Walter, what's in the symbol? how many frames in the nested symbol and what are on those frames? Is the ActionScript version AS 2.0 or AS 3.0 in the fla? Please try closing the Properties Inspector, then double click on the symbol to enter the edit mode and see if you can reproduce the problem.
                      San
                      • 8. Re: Flash 8 to CS4 upgrade...files are running slow
                        Thanks for all your good efforts, San! Hope we'll find a solution soon before they eat me alive over here :-) J/K
                        thanks,
                        tharaka
                        • 9. Flash 8 to CS4 upgrade...files are running slow
                          San, I'll answer your last question very simply:
                          EVERY symbol. Not just one. EVERY symbol. Check your PM. I wrote you even more details.
                          All symbols are cartoon animation drawings: fingers, hands, legs, background elements. You name it. All just plain drawings with lines and fills. Quite a few are nested animations. But it is not only the nested animations which have the terrible delay. Did I say it? Every symbol.
                          Not just symbols. Everything about these files is slow. Click on the lock to unlock or lock all layers. You have time to go make a cup of coffee between the moment you click and when all the layers respond. Even if there are only 3 layers in a symbol.
                          The FLAs are Flash 8, AS2, but containing no ActionScript.
                          I'm working on a project created in Flash 8. It contains 8 different FLA files of around 3 minutes animation each, at 25 fps. So between 3000 and 5000 frames. Each scene within those FLAs is a nested animation. So for example, scene 1 is 350 frames, within a Graphic Symbol. That symbol is placed on the timeline for 350 frames. And so on. Inside those nested animations are more nested animations of individual characters. Inside the character symbols are more nested animations for things such as the character mouths. This is an absolutely unremarkable and normal workflow for animation production in Flash.
                          I tried working on over a dozen such files (in CS4), created by different people on different computers in different OSs, but all done in Flash 8. Same trouble. It's obviously CS4's inability to manage a file with hundreds of nested symbols.
                          Never was a problem until CS4 came along. I wish I could somehow let you try these files. But between the NDA requirements and the file sizes, it seems not possible.
                          And please check your PM about the other lethal problem of the Graphic Symbols resetting when color effects are applied. Between the lag problem and the Graphic Symbol resetting bug, I've sounded the alarm to all the animators I know to postpone getting Flash CS4 until these troubles are fixed. Which is too bad, since you guys really tried to give us animators a treat with the IK and Motion Editor.
                          • 10. Re: Flash 8 to CS4 upgrade...files are running slow
                            hey san,
                            any progress? let us know!
                            thanks,
                            tharaka
                            • 11. Re: Flash 8 to CS4 upgrade...files are running slow
                              san_flash Level 2
                              The NDA request will take very long and I'm not sure if it'll even be possible for us to get one signed with you. However, we're able to get a file with a similar reported problem without signing the NDA so we're looking at trying to reproduce it now. Will post an update.
                              San
                              • 12. Re: Flash 8 to CS4 upgrade...files are running slow
                                san_flash Level 2
                                We're able to reproduce the performance issues with the file we received. However, we can't be 100% sure that they are the same problems that you are running into with your files. Please stay tune. We're looking at the problems and might need your help confirming the fix with your files.
                                San
                                • 13. Re: Flash 8 to CS4 upgrade...files are running slow
                                  San, instead of waiting to confirm a fix with files that brain00053 and I can't send you for legal reasons, why not simply fix the problem you've detected and publicly release a patch to Flash which addresses this and the many other bugs which have been confirmed? Or at least let those of us with this and other problems have a test version of the program to see whether your solutions work for all these bugs? I'll be glad to sign an NDA with Adobe, promising not to release the test version of Flash CS4 to anyone else.
                                  • 14. Re: Flash 8 to CS4 upgrade...files are running slow
                                    san_flash Level 2
                                    Hi Walter,
                                    As I said before, please stay tune. We're investigating the problem to find a safe fix for it.
                                    San
                                    • 15. Re: Flash 8 to CS4 upgrade...files are running slow
                                      Hi San,
                                      Any breaking news? let us know!
                                      thanks,
                                      tharaka
                                      • 16. Re: Flash 8 to CS4 upgrade...files are running slow
                                        abeall Level 3
                                        Try changing the ActionScript version to 2.0 if that is an option. I've also found that AS3 projects in both CS3 and CS4 go horribly slow when you try to work inside symbols.
                                        • 17. Re: Flash 8 to CS4 upgrade...files are running slow
                                          Hi San,
                                          Any updates?
                                          thanks,
                                          tharaka
                                          • 18. Re: Flash 8 to CS4 upgrade...files are running slow
                                            I'd like to know the latest too. And get a patch to use CS4 properly.
                                            And by the way, changing ActionScript version makes no difference. All I'm doing (and Brain00053 too) is opening Flash 8 projects in CS4. They are AS2 format to begin with.
                                            • 19. Re: Flash 8 to CS4 upgrade...files are running slow
                                              Hey San,
                                              Happy New Year! Please get back to us with an update. it's been almost 2 weeks since we last heard back from you. Please also tell us when you think will Adobe have a fix for this issue.
                                              Tharaka
                                              • 20. Re: Flash 8 to CS4 upgrade...files are running slow
                                                san_flash Level 2
                                                We're looking at the problems. I'm sorry I can't say if there will be a patch. However, we are aware of these performance issues and taking them seriously.
                                                San
                                                • 21. Flash 8 to CS4 upgrade...files are running slow
                                                  quote:
                                                  San
                                                  So, San, let me try to understand your reply: You are "aware of these problems" and you are "looking at them", but I notice you didn't actually say "we are working on them."
                                                  That's like a doctor saying he's aware that the patient's shin bone is sticking out of his skin, and he's looking at it, but can't say whether he'll actually fix it.
                                                  My interpretation of your answer is that no one is actually putting any effort into fixing the code to come up with a proper working version of Flash CS4. How accurate is my statement, on a scale of 0 to 10?
                                                  I know you just work there and have the best intentions. But I hope you'll relay to your management just how useful Flash CS4, without a fix, is in real-world production: 0.
                                                  • 22. Re: Flash 8 to CS4 upgrade...files are running slow
                                                    Hi San,
                                                    any progress? please update us!
                                                    thanks,
                                                    tharaka
                                                    • 23. Re: Flash 8 to CS4 upgrade...files are running slow
                                                      C-Rock Level 2
                                                      I've found this problem with all Flash version if what you're trying to move or even select is too complicated.
                                                      For instance I had a project that used a large vector map of the US. The map was fairly detailed. If you looked closely the edges were very jagged meaning Flash had to use memory and gpu power just to draw each pixel. Because of this it performed slow doing anything with the map on the stage. Flash 8.
                                                      Flash forward to CS4, I imported a text animation from AE today like many times before but this one was a little more complex. When trying to position this clip I would have to select all the frames and all the objects by using the multiple frame select. This took over 10 seconds for Flash to respond to a simple shift+up arrow command. Just because Flash had to use so many resources to draw it.
                                                      Now why is it more slow in CS4 than 8? CS4 was rushed and is crap in my opinion. I've owned each flash from flash 3 and this is the worst, by far. This is Adobe's first real release of Flash.
                                                      I would say the best thing you can do is make your view the lowest quality as possible and hide all text on the stage. That may improve your redrawing so you can at least work.
                                                      Flash needs the ability to adjust performace similar to PS and AE. I have 12 GB's of memory and a $1,000 cpu but Flash doesn't tap into much of it at all.
                                                      • 24. Re: Flash 8 to CS4 upgrade...files are running slow
                                                        san_flash Level 2
                                                        Here's an update. We are working on fixing some bugs at this moment. Please understand that there are rules that I need to follow in what I can say on the forums. I'm allowed to say that we are working on some bug fixes. However, I cannot say if there's a patch coming or not.
                                                        San
                                                        • 25. Re: Flash 8 to CS4 upgrade...files are running slow
                                                          captain_code-KOo9rr
                                                          The sad thing, is you don't even have to be animating for the performance to be incredibly slow. I don't do animation, so I can't sympathize with that but my application fla is the same way when there are a decent (what I thought somewhat small or standard) number of objects on the stage, the time is SLOW. I do lots of code based projects, so something else that is really slow: try right-clicking on an exported symbol, and choosing properties. CS4's record to date: 15 Seconds. WHY? One thing I have noticed with it, is it appears to be reading something from my network. Isn't the file already open in memory? Or at least paged on to the HD?
                                                          • 26. Re: Flash 8 to CS4 upgrade...files are running slow
                                                            san_flash Level 2
                                                            flashster,
                                                            Is your document AS 2.0 or AS 3.0? If it's AS 3.0, please try narrowing it down for us by changing it to AS 2.0 and see if it's still slow. If it's happening in AS 2.0 file, it's similar to the performance problems that were reported in this thread and I'd like to confirm that.
                                                            San
                                                            • 27. Re: Flash 8 to CS4 upgrade...files are running slow
                                                              Fede Rivas
                                                              I have simply discard CS4 and go backward to CS3, it was impossible for me to work.
                                                              As other users, i'm not an animator, and have few mc's at stage, most of them with classes attached, and is a real hell to try to work, most if you have some .fla opened.
                                                              I hope Adobe work in a decent update, i thing it's a shame for a company like adobe release a "final version" like the one we have. It's more like a beta.
                                                              • 28. Re: Flash 8 to CS4 upgrade...files are running slow
        san_flash Level 2
        Fede Rivas and the flashster,
        Is it possible to provide us the source fla? We're fixing some performance bugs and it'll be great to check whether your case is covered or not.
        If you're sending zip file, please change the file extension to .zzz so it can get through our mail filter.
        We're unable to sign a NDA for your files but we'll use your file for testing purposes only.
        San
        • 29. Re: Flash 8 to CS4 upgrade...files are running slow
        Fede Rivas Level 1
        Hi San.
        I can send you the file, but my problem wasn't a concrete file, the problem was opening some files at the same time.
        I use to write code in TextMate, and when i back to flash to compile, it hangs about 15 secs to respond. With more than 5 files opened, it turns very very slow, and takes over 10 seconds to respond a simple select to an mc in the stage, and over 15 sec. to respond to a right click over a library simbol.
        While i was suffering that problems, i see in my Activity Monitor ( OSX 10.5 ) that CS4 uses more than 40% of the cpu in standby, and more than 75% while working, making all the computer feels like an old PII 300 .
        When CS4 was restarted, things seems to work again, but after some minutes of work, it was the same.
        If you want, i can collect the files and send them to you, you can't compile them due to the large amount of classes used in that files ( we dont send classes ), but you can test the authoring tool with them.
        • 30. Flash 8 to CS4 upgrade...files are running slow
        Fede Rivas Level 1
        Please delete this post, messagepost.cfm fails and posts twice the same.
        • 31. Re: Flash 8 to CS4 upgrade...files are running slow
        san_flash Level 2
        Fede Rivas,
        Please send me the files, especially the fla file and let me know the symbol that takes long to select. Is there 3D in any of the fla files?
        San
        • 32. Flash 8 to CS4 upgrade...files are running slow
        san_flash Level 2
        Richard Galvan, Flash product manager, has posted the status of some of the bugs on his blog.
        http://blogs.adobe.com/rgalvan/
        He'll update his blog when there is more information.
