• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
How to batch rename "YYYY-MM-DD - HH.MM.SS - Name - Sequence" in bridge
New Here ,
Nov 22, 2016 Nov 22, 2016
Hi there,
I want to rename a whole lot of videos in a very specific scheme in Adobe Bridge CC.
The scheme goes like:
YYYY-MM-DD - HH.MM.SS - Name - 001
The only place where I got a problem is with the HH.MM.SS part. I can choose HHMMSS, but cannot enter HH, MM or SS seperatly, and I really want the dot to separate them. I can do that in Lightroom but Bridge is much more interesting to work with in terms of organizing and renaming videos (like detail view instead of thumbnails, for instance). I'm sure there's a way to do this.
Thanks in advance for any constructive advice
Views
1.5K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert ,
For a 100% only Bridge workflow, I think that this will require the renaming to be performed in two passes:
1st Pass = Basic Rename
2nd Pass = String Substitution using a RegEx find/replace
For a single step workflow, I would recommend using the free ExifTool application
Votes
Translate
Translate
Report
Report
New Here ,
The first option seems more complicated than with Lightroom so it's out of the way.
For the second, I never used ExifTool. Can I batch rename with that?
Votes
Translate
Translate
Report
Report
Community Expert ,
Sure, you can recursively batch re-name, however you will need to use some code. There is a forum which can help you search for a previous answer or ask a new one…
Votes
Translate
Translate
Report
Report
New Here ,
Ok. As someone who never coded a single line, would you recommend it to me or should I stick with using Lightroom?
Votes
Translate
Translate
Report
Report
Community Expert ,
Depends on your pain! :]
Votes
Translate
Translate
Report
Report
Community Expert ,
Somebody with better RegEx than I can probably do the 2nd pass regular expression rename in a single step… I had to break down the RegEx into two steps… so three steps in total:
Step 1:
Step 2:
Step 3:
All of these batch rename search/replace commands can be saved as a preset.
So select all files in Bridge and run three separate rename presets… Or use Lightroom… Or some other software for renaming, there are many of them out there.
Votes
Translate
Translate
Report
Report
Community Expert ,
Nov 23, 2016 Nov 23, 2016
OK, for the record, I figured out the regular expression to combine step 2 & 3 into a single step!
Step 1
Step 2
(?<=\d{8}\s-\s\d\d)
Step 3
(?<=\d{8}\s-\s\d\d\.\d\d)
_____________
The new combined regex pattern would be:
Step 1
(NEW) Step 2
(?<=\d{8}\s-\s\d{2})|(?<=\d{8}\s-\s\d{4})
Votes
Translate
Translate
Report
Report
Community Expert ,
I also belatedly saw the obvious… Rather than combining the two separate regex patterns into a single regex pattern, I could have just used the GUI to combine the two separate regex patterns together!
Votes
Translate
Translate
Report
Report
Community Expert ,
Which of course leads me to the holy grail – a combined single step batch rename as originally requested!
or using the combined regex (?<=\d{8}\s-\s\d{2})|(?<=\d{8}\s-\s\d{4}) for the same result:
So, who needs Lightroom now?
Votes
Translate
Translate
Report
Report
Community Expert ,
Feb 17, 2017 Feb 17, 2017
LATEST
I found an error in my previous example, the OP required the year-month-day pattern to be delimited with hyphens, where as my original example did not show this.
I have corrected this and posted a blog entry here:
Prepression: Bridge vs. Lightroom Batch Rename Comparison
The regex should read as:
(?<=\d{4}-\d{2}-\d{2}\s-\s\d{2})|(?<=\d{4}-\d{2}-\d{2}\s-\s\d{4})
Addendum:
Another regular expression that achieves the same result:
Find = (^.+?\s-\s.{2})(.{2})(.{2})(.+)
Replace = $1.$2.$3$4
Votes
Translate
Translate
Report
Report
