• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Vector Graphics in PSD and ID
Community Beginner ,
Nov 23, 2016 Nov 23, 2016
I am trying to create a vector graphic in PS CS6.  First, is this possible?  I have saved images as EPS files but when I place them in my ID program they are pixelated. I'm totally unfamiliar with vector graphics creation and need guidance. Thanks.
Tamlyn
Views
625
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Nov 23, 2016 Nov 23, 2016
Why are you using Photoshop for this? Illustrator would be a far better choice.
Votes
Translate
Translate
Community Expert ,
Vectors from Photoshop can only be saved as a Photoshop PDF file, otherwise they are rasterized.
Votes
Translate
Translate
Report
Report
Explorer ,
Hi Tamlyn
Steve is correct. I'm interested to know what the end use is for these? Online or print?  Do the files need to be vector for some particular reason? You may be able to create the images you need and just save them at a higher resolution to avoid pixelation. InDesign works well with straight PSD or JPG files. EPS is a bit of a throwback these days. Perhaps if you can post a screen shot of an example image, we could give you a bit more guidance.
Votes
Translate
Translate
Report
Report
It will be used for business front signage.
Tamlyn
Votes
Translate
Translate
Report
Report
Votes
Translate
Translate
Report
Report
Community Expert ,
Do it in InDesign. Shouldn't take more than 5-10 minutes.
Votes
Translate
Translate
Report
Report
Community Expert ,
Votes
Translate
Translate
Report
Report
Can I use InDesign?  I don't believe I have Illustrator.
Tamlyn
Votes
Translate
Translate
Report
Report
Explorer ,
Yes, as Bob said, you should be able to do this in InDesign. If the file needs to be vector based for the company that is producing the sign, once you have the text sized how you want, just go to Type>Create Outlines. You can export that to PDF if needed.
Votes
Translate
Translate
Report
Report
Nov 25, 2016 Nov 25, 2016
Unfortunately "Create Outlines" is not an option in my InDesign program under "Type."
Votes
Translate
Translate
Report
Report
Community Expert ,
LATEST
You need to select it first but there’s no reason to do so.
Votes
Translate
Translate
Report
Report
