2 Replies Latest reply on Nov 24, 2016 1:51 AM by vinny38
    Indesign text import – more efficient way
    floydpeter214 Level 1
      iam trying to figure out a faster way to do one task we sometimes get at work. Basically we receive a text like this:
      Company name
      Client name
      Function
      Adress:...
      Adress2....
      Contact:...
      Other:
      Other:
      Lorem ipsum text around 200 characters.
      Each of those paragraphs have to start at specified spot and be properly formatted. What i do is setup a table with formatted cells and then just select it all and paste in the text from excel table. But i still have to massage it a little bit after that – for example it wont import hard returns from excel file which messes up some of my styles and of course the aforementioned 200 character text have to be imported separately.
      Is there some better/more efficient way to do this? And is there a way to import hard returns when copying from excel?
      Thank you very much
      F.
        • 1. Re: Indesign text import – more efficient way
          tpk1982 Level 4
          HI..
          Try Data Merge option
          • 2. Re: Indesign text import – more efficient way
            vinny38 Level 5
            Hi
            In addition of tpk1982's advice, I must say that Excel hard returns are usually (always...) messing up Data Merge.
            As I often use Data Merge, I always run a macro that get rids of them in my Excel file.
            Here it is, you might find it helpful:
            Sub KillHardReturns()
                Dim MyRange As Range
                Application.ScreenUpdating = False
                Application.Calculation = xlCalculationManual
                For Each MyRange In ActiveSheet.UsedRange
                    If 0 < InStr(MyRange, Chr(10)) Then
                        MyRange = Replace(MyRange, Chr(10), "")
                    End If
                Next
                Application.ScreenUpdating = True
                Application.Calculation = xlCalculationAutomatic
            End Sub
            Regards
