5 Replies Latest reply on Nov 27, 2016 4:46 PM by grayn31999337
    How to strikeout a block of text.
    grayn31999337
      Hi, I am a total newbie to Adobe Java (I am a vb programmer) and I am trying to apply strikeout to a block of text.
      My possible options are :-
      1. Add a checkbox or radio button to the left of each block of text. When a box is ticked then all the other options need to have the strikeout applied to the associated text. As the text is not in a textbox I tried adding a line, made of underscores, to a rich textbox and tried to make the mouseup event on the checkbox make the rich textbox visible. I get an error on line 1. Invalid something.
      2.Another idea was to duplicate the text in a rich textbox with strikeout true and making the textbox visible. Same problem.
      I think I am missing something either in the setup or the terminology.
      Any help would be greatly appreciated.
      Another alternative is if I can be pointed to a beginners set of tutorials. I am not having any luck finding some.
      Many thanks,
      Gray
        • 1. Re: How to strikeout a block of text.
          JR_Boulay Adobe Community Professional
          Hi.
          Create a (empty, readonly, no fillcolor) text field with stroke properties settled to "underlined" and name it "strikeout".
          Then use right-clic : Create multiple copy to get several fields with a consistent naming (.0, .1, .2, etc.).
          Now you just have to show/hide all these "lines" with this JavaScript:
          this.getField("strikeout").display = display.visible;
          or
          this.getField("strikeout").display = display.hidden;
          Adobe Java
          As a programmer you should know that Java is not Adobe and is not JavaScript.
          • 2. Re: How to strikeout a block of text.
            I agree, terminology. As long as you look for information on Java you won't find anything useful.
            • 3. Re: How to strikeout a block of text.
              grayn31999337 Level 1
              Thanks for the reply. That is almost identical to what I was using (I was using an string of Underscore instead of the Stroke Property Underlined - which I cannot find) but I still get the following error.
              Javascript code in Check Box2 MouseUp event
                        this.getfield("strikeout").display=display.hidden
              Error received
                        Exception in line 1 of function top_level, script Field:Mouse Up
              To me it sounds like there is some setting I have not set.
              Thanks for your help.
              • 4. Re: How to strikeout a block of text.
                JS is case-sensitive. The name of the function you're trying to use is getField, not getfield ...
                2 people found this helpful
                • 5. Re: How to strikeout a block of text.
                  Thanks try67. Although JR_Boulay did give the correct answer I already have tried that code. Being a VB programmer I was not aware that commands were case sensitive.
                  So thank you to both of you.
                  In future I will paste my code for scrutiny.
