2 Replies Latest reply on Nov 24, 2016 2:16 PM by David_Entwistle
    How to apply fillColor tint?
    David_Entwistle Level 1
      Hello – my script reads a CSV file (which holds path names and corresponding tint values) and tries to apply a tint to each named path. All paths have previously been filled with 100% of a Spot color.
      The script (below) builds on something that Muppet Mark generously supplied for someone else's question a while back. It works fine if I change the opacity of the objects, but not if I change the tints. Can anyone please show what I'm doing wrong?
      Many thanks.
      #target Illustrator
      applydatafile();
      function applydatafile() {
                if ( app.documents.length == 0 ) { return; }
                var doc, csvFile, i, fileArray;
                csvFile = File.openDialog("Choose the CSV file");
                if ( !csvFile.exists ) { return; }
                fileArray = readInCSV( csvFile );
                doc = app.activeDocument;
                // For each line of the data file...
                for ( i = 0; i < fileArray.length; i++ ) {
                // ...get the named path [i][0] and give it property value [i][1]
                // this works: doc.pathItems.getByName( fileArray[i][0] ).opacity = fileArray[i][1];
                // but the following line has no effect:
                doc.pathItems.getByName( fileArray[i][0] ).fillColor.tint = fileArray[i][1];
      function readInCSV( fileObj ) {
                var fileArray, thisLine, csvArray;
                fileArray =[];
                fileObj.open( 'r' );
                while( !fileObj.eof ) {
                          thisLine = fileObj.readln();
                          csvArray = thisLine.split( ',' );
                          fileArray.push( csvArray );
                fileObj.close();
                return fileArray;
      CSV file contents:
      one,35
      two,55
      three,75
      four,95
      Message was edited by: David Entwistle to aid clarity.
        • 1. Re: How to apply fillColor tint?
          pixxxel schubser MVP & Adobe Community Professional
          Hi David_Entwistle
          how about this?
          applydatafile();
              var doc, csvFile, i, fileArray, pI;
                  pI = doc.pathItems.getByName( fileArray[i][0] );
                  if (pI.fillColor.tint == 100) { // change only if tint value == 100
                  pI.fillColor.tint = pI.fillColor.tint *(fileArray[i][1]/100);
                    fileArray =[];
                              $.writeln (fileArray);
                    fileObj.close();
                    return fileArray;
          Have fun
          • 2. Re: How to apply fillColor tint?
            Thank you! That does the trick, and very neatly.
            (I had to add some semi-colons after the closing braces, lines 15–17, but not sure if that's something to do with my set-up.)
            Very grateful for your coding and your time – thank you again.
