1 Reply Latest reply on Nov 25, 2016 10:27 AM by vendasv46176141
    phonegap api level 14
    vendasv46176141
      Hello I compiled today my project after the changes of the plugins (15th November) and when specifying the minimum sdk I noticed that in the log it did not compile in the lightweight api that I defined. This, an error occurs in my app on the Samsung Tablet tab 3 (android version 4.2.2). I own a build prior to November 15th that works properly on the Samsung Tablet tab3 My compilation: https://build.phonegap.com/apps/2367688/ my config.xml
      <preference name="permissions" value="none" />
          <preference name="phonegap-version" value="3.7.0" />
          <preference name="orientation" value="default" />
          <preference name="target-device" value="universal" />
          <preference name="fullscreen" value="false" />
          <preference name="webviewbounce" value="true" />
          <preference name="prerendered-icon" value="true" />
          <preference name="stay-in-webview" value="false" />
          <preference name="ios-statusbarstyle" value="black-opaque" />
          <preference name="detect-data-types" value="true" />
          <preference name="exit-on-suspend" value="false" />
          <preference name="show-splash-screen-spinner" value="true" />
          <preference name="auto-hide-splash-screen" value="true" />
          <preference name="disable-cursor" value="false" />
          <preference name="android-installLocation" value="auto" />
        <preference name="KeepRunning" value="true"/>
        <preference name="AndroidPersistentFileLocation" value="Compatibility" />
        <preference name="android-build-tool" value="gradle" />
        <plugin name="cordova-plugin-dialogs" spec="~1.3.0" />
        <plugin name="cordova-plugin-splashscreen" spec="~4.0.0" />
        <plugin name="cordova-plugin-vibration" spec="~2.1.2" />
        <plugin name="cordova-plugin-device" spec="~1.1.3" />
        <plugin name="cordova-plugin-network-information" spec="~1.3.0" />
        <plugin name="phonegap-plugin-push-deprecated" source="npm"/>
        <plugin name="cordova-plugin-inappbrowser" spec="~1.5.0" />
        <plugin name="cordova-plugin-geolocation" spec="~2.4.0" />
        <plugin name="cordova-plugin-x-toast" source="npm"/>
        <plugin name="cordova-plugin-barcodescanner" source="npm"/>
        <plugin name="cordova-plugin-media" spec="~2.4.0" />
        <icon src="icon.png" />
        <platform name="android">
        <preference name="AndroidLaunchMode" value="singleTop"/>
        <preference name="android-minSdkVersion" value="14" />
        <preference name="android-targetSdkVersion" value="14" />
        <icon src="res/screen/android/screen-mdpi-portrait.png" density="mdpi" />
        <icon src="res/screen/android/screen-hdpi-portrait.png" density="hdpi" />
        <icon src="res/screen/android/screen-xhdpi-portrait.png" density="xhdpi" />
        </platform>
        <access origin="*" />
      my log phonegap
      Build Date: 2016-11-24 18:01:47 +0000
      PLUGIN OUTPUT
      Fetching plugin "cordova-plugin-dialogs@~1.3.0" via npm
      Installing "cordova-plugin-dialogs" at "1.3.0" for android
       Using this version of Cordova with older version of cordova-android is being deprecated. Consider upgrading to cordova-android@5.0.0 or newer.
      Fetching plugin "cordova-plugin-splashscreen@~4.0.0" via npm
      Installing "cordova-plugin-splashscreen" at "4.0.0" for android
      Fetching plugin "cordova-plugin-vibration@~2.1.2" via npm
      Installing "cordova-plugin-vibration" at "2.1.2" for android
      Fetching plugin "cordova-plugin-device@~1.1.3" via npm
      Installing "cordova-plugin-device" at "1.1.3" for android
      Fetching plugin "cordova-plugin-network-information@~1.3.0" via npm
      Installing "cordova-plugin-network-information" at "1.3.0" for android
      Fetching plugin "phonegap-plugin-push-deprecated" via npm
      Installing "phonegap-plugin-push-deprecated" at "2.5.0-pgb-1" for android
      Fetching plugin "cordova-plugin-inappbrowser@~1.5.0" via npm
      Installing "cordova-plugin-inappbrowser" at "1.5.0" for android
      Fetching plugin "cordova-plugin-geolocation@~2.4.0" via npm
      Installing "cordova-plugin-geolocation" at "2.4.0" for android
      Fetching plugin "cordova-plugin-compat" via npm
      Installing "cordova-plugin-compat" at "1.1.0" for android
      Fetching plugin "cordova-plugin-x-toast" via npm
      Installing "cordova-plugin-x-toast" at "2.5.2" for android
      Fetching plugin "cordova-plugin-barcodescanner" via npm
      Installing "cordova-plugin-barcodescanner" at "0.7.0" for android
      Fetching plugin "cordova-plugin-media@~2.4.0" via npm
      Installing "cordova-plugin-media" at "2.4.0" for android
      Fetching plugin "cordova-plugin-file" via npm
      Installing "cordova-plugin-file" at "4.3.0" for android
      Dependent plugin "cordova-plugin-compat" already installed on android.
      The Android Persistent storage location now defaults to "Internal". Please check this plugins README to see if you application needs any changes in its config.xml.
      If this is a new application no changes are required.
      If this is an update to an existing application that did not specify an "AndroidPersistentFileLocation" you may need to add:
        "<preference name="AndroidPersistentFileLocation" value="Compatibility" />"
      to config.xml in order for the application to find previously stored files.
      COMPILE OUTPUT
      Buildfile: /project/build.xml
      -set-mode-check:
      -set-debug-files:
      -check-env:
       [checkenv] Android SDK Tools Revision 25.2.2
      -setup:
        [echo] Project Name: GEPLAN
        [gettype] Project Type: Application
      -set-debug-mode:
      -debug-obfuscation-check:
      -pre-build:
      -build-setup:
      [getbuildtools] Using latest Build Tools: 24.0.1
        [echo] Resolving Build Target for GEPLAN...
      [gettarget] Project Target: Android 5.0.1
      [gettarget] API level: 21
        [echo] ----------
        [echo] Creating output directories if needed...
        [mkdir] Created dir: /project/bin
        [mkdir] Created dir: /project/bin/res
        [mkdir] Created dir: /project/bin/rsObj
        [mkdir] Created dir: /project/bin/rsLibs
        [mkdir] Created dir: /project/gen
        [mkdir] Created dir: /project/bin/classes
        [mkdir] Created dir: /project/bin/dexedLibs
        [echo] ----------
        [echo] Resolving Dependencies for GEPLAN...
      [dependency] Library dependencies:
      [dependency]
      [dependency] ------------------
      [dependency] Ordered libraries:
      [dependency]
        [echo] ----------
        [echo] Building Libraries with 'debug'...
      nodeps:
      -set-mode-check:
      -set-debug-files:
      -check-env:
      -setup:
        [echo] Project Name: CordovaLib
        [gettype] Project Type: Android Library
      -set-debug-mode:
      -pre-build:
      -build-setup:
        [echo] Resolving Build Target for CordovaLib...
        [echo] ----------
        [mkdir] Created dir: /project/CordovaLib/res
        [mkdir] Created dir: /project/CordovaLib/libs
        [mkdir] Created dir: /project/CordovaLib/bin
        [mkdir] Created dir: /project/CordovaLib/bin/res
        [mkdir] Created dir: /project/CordovaLib/bin/rsObj
        [mkdir] Created dir: /project/CordovaLib/bin/rsLibs
        [mkdir] Created dir: /project/CordovaLib/gen
        [mkdir] Created dir: /project/CordovaLib/bin/classes
        [mkdir] Created dir: /project/CordovaLib/bin/dexedLibs
        [echo] ----------
        [echo] Resolving Dependencies for CordovaLib...
      [dependency] No Libraries
      [dependency]
      -code-gen:
      [mergemanifest] Merging AndroidManifest files into one.
      [mergemanifest] Manifest merger disabled. Using project manifest only.
        [echo] Handling aidl files...
        [aidl] No AIDL files to compile.
        [echo] ----------
        [echo] Handling RenderScript files...
        [echo] ----------
        [echo] Handling Resources...
        [aapt] Generating resource IDs...
        [echo] ----------
        [echo] Handling BuildConfig class...
      [buildconfig] Generating BuildConfig class.
      -pre-compile:
      -compile:
        [javac] Compiling 98 source files to /project/CordovaLib/bin/classes
        [javac] warning: [options] source value 1.5 is obsolete and will be removed in a future release
        [javac] warning: [options] target value 1.5 is obsolete and will be removed in a future release
        [javac] warning: [options] To suppress warnings about obsolete options, use -Xlint:-options.
        [javac] Note: Some input files use or override a deprecated API.
        [javac] Note: Recompile with -Xlint:deprecation for details.
        [javac] 3 warnings
        [echo] Creating library output jar file...
        [jar] Building jar: /project/CordovaLib/bin/classes.jar
      -post-compile:
      -obfuscate:
      -dex:
        [echo] Library project: do not convert bytecode...
      -crunch:
        [crunch] Crunching PNG Files in source dir: /project/CordovaLib/res
        [crunch] To destination dir: /project/CordovaLib/bin/res
        [crunch] Crunched 0 PNG files to update cache
      -package-resources:
        [echo] Library project: do not package resources...
      -package:
        [echo] Library project: do not package apk...
      -post-package:
      -do-debug:
        [echo] Library project: do not create apk...
      [propertyfile] Creating new property file: /project/CordovaLib/bin/build.prop
      [propertyfile] Updating property file: /project/CordovaLib/bin/build.prop
      -post-build:
      debug:
      -code-gen:
        [echo] ----------
        [echo] ----------
        [aapt] warning: string 'menu_settings' has no default translation.
        [echo] ----------
      -pre-compile:
      -compile:
        [javac] Compiling 37 source files to /project/bin/classes
        [javac] Note: /project/src/org/apache/cordova/file/AssetFilesystem.java uses unchecked or unsafe operations.
        [javac] Note: Recompile with -Xlint:unchecked for details.
        [javac] 3 warnings
      -post-compile:
      -obfuscate:
      -dex:
        [dex] input: /project/bin/classes
        [dex] input: /project/CordovaLib/bin/classes.jar
        [dex] input: /project/libs/com.google.zxing.client.android.captureactivity.jar
        [dex] input: /project/libs/gcm.jar
        [dex] input: /project/libs/android-support-v13.jar
        [dex] Pre-Dexing /project/CordovaLib/bin/classes.jar -> classes-50c94eb6949a554121683648bde1aeec.jar
        [dex] Pre-Dexing /project/libs/com.google.zxing.client.android.captureactivity.jar -> com.google.zxing.client.android.captureactivity-2a6b08981b6480a61341a68ddf0e6c02.jar
        [dex] Pre-Dexing /project/libs/gcm.jar -> gcm-fe9ac4fa7558dca9ed65bd70253029dd.jar
        [dex] Pre-Dexing /project/libs/android-support-v13.jar -> android-support-v13-c1d2053b6c2c09de22134ebfd5b0f4c5.jar
        [dex] Converting compiled files and external libraries into /project/bin/classes.dex...
        [dx] Merged dex #1 (131 defs/163.5KiB)
        [dx] Merged dex #2 (958 defs/977.4KiB)
        [dx] Merged dex #3 (223 defs/325.8KiB)
        [dx] Merged dex #4 (343 defs/552.5KiB)
        [dx] Merged dex #5 (4 defs/18.7KiB)
        [dx] Result is 1659 defs/2535.7KiB. Took 0.5s
      -crunch:
        [crunch] Crunching PNG Files in source dir: /project/res
        [crunch] To destination dir: /project/bin/res
        [crunch] Processing image to cache: /project/res/drawable-hdpi/ic_action_next_item.png => /project/bin/res/drawable-hdpi/ic_action_next_item.png
        [crunch] (processed image to cache entry /project/bin/res/drawable-hdpi/ic_action_next_item.png: 0% size of source)
        [crunch] Processing image to cache: /project/res/drawable-hdpi/ic_action_previous_item.png => /project/bin/res/drawable-hdpi/ic_action_previous_item.png
        [crunch] (processed image to cache entry /project/bin/res/drawable-hdpi/ic_action_previous_item.png: 0% size of source)
        [crunch] Processing image to cache: /project/res/drawable-hdpi/ic_action_remove.png => /project/bin/res/drawable-hdpi/ic_action_remove.png
        [crunch] (processed image to cache entry /project/bin/res/drawable-hdpi/ic_action_remove.png: 0% size of source)
        [crunch] Processing image to cache: /project/res/drawable-hdpi/icon.png => /project/bin/res/drawable-hdpi/icon.png
        [crunch] (processed image to cache entry /project/bin/res/drawable-hdpi/icon.png: 16% size of source)
        [crunch] Processing image to cache: /project/res/drawable-hdpi/launcher_icon.png => /project/bin/res/drawable-hdpi/launcher_icon.png
        [crunch] (processed image to cache entry /project/bin/res/drawable-hdpi/launcher_icon.png: 0% size of source)
        [crunch] Processing image to cache: /project/res/drawable-hdpi/shopper_icon.png => /project/bin/res/drawable-hdpi/shopper_icon.png
        [crunch] (processed image to cache entry /project/bin/res/drawable-hdpi/shopper_icon.png: 0% size of source)
        [crunch] Processing image to cache: /project/res/drawable-ldpi/icon.png => /project/bin/res/drawable-ldpi/icon.png
        [crunch] (processed image to cache entry /project/bin/res/drawable-ldpi/icon.png: 10% size of source)
        [crunch] Processing image to cache: /project/res/drawable-mdpi/ic_action_next_item.png => /project/bin/res/drawable-mdpi/ic_action_next_item.png
        [crunch] (processed image to cache entry /project/bin/res/drawable-mdpi/ic_action_next_item.png: 0% size of source)
        [crunch] Processing image to cache: /project/res/drawable-mdpi/ic_action_previous_item.png => /project/bin/res/drawable-mdpi/ic_action_previous_item.png
        [crunch] (processed image to cache entry /project/bin/res/drawable-mdpi/ic_action_previous_item.png: 0% size of source)
        [crunch] Processing image to cache: /project/res/drawable-mdpi/ic_action_remove.png => /project/bin/res/drawable-mdpi/ic_action_remove.png
        [crunch] (processed image to cache entry /project/bin/res/drawable-mdpi/ic_action_remove.png: 0% size of source)
        [crunch] Processing image to cache: /project/res/drawable-mdpi/icon.png => /project/bin/res/drawable-mdpi/icon.png
        [crunch] (processed image to cache entry /project/bin/res/drawable-mdpi/icon.png: 12% size of source)
        [crunch] Processing image to cache: /project/res/drawable-xhdpi/ic_action_next_item.png => /project/bin/res/drawable-xhdpi/ic_action_next_item.png
        [crunch] (processed image to cache entry /project/bin/res/drawable-xhdpi/ic_action_next_item.png: 0% size of source)
        [crunch] Processing image to cache: /project/res/drawable-xhdpi/ic_action_previous_item.png => /project/bin/res/drawable-xhdpi/ic_action_previous_item.png
        [crunch] (processed image to cache entry /project/bin/res/drawable-xhdpi/ic_action_previous_item.png: 0% size of source)
        [crunch] Processing image to cache: /project/res/drawable-xhdpi/ic_action_remove.png => /project/bin/res/drawable-xhdpi/ic_action_remove.png
        [crunch] (processed image to cache entry /project/bin/res/drawable-xhdpi/ic_action_remove.png: 0% size of source)
        [crunch] Processing image to cache: /project/res/drawable-xhdpi/icon.png => /project/bin/res/drawable-xhdpi/icon.png
        [crunch] (processed image to cache entry /project/bin/res/drawable-xhdpi/icon.png: 22% size of source)
        [crunch] Processing image to cache: /project/res/drawable-xhdpi/launcher_icon.png => /project/bin/res/drawable-xhdpi/launcher_icon.png
        [crunch] (processed image to cache entry /project/bin/res/drawable-xhdpi/launcher_icon.png: 46% size of source)
        [crunch] Processing image to cache: /project/res/drawable-xxhdpi/ic_action_next_item.png => /project/bin/res/drawable-xxhdpi/ic_action_next_item.png
        [crunch] (processed image to cache entry /project/bin/res/drawable-xxhdpi/ic_action_next_item.png: 0% size of source)
        [crunch] Processing image to cache: /project/res/drawable-xxhdpi/ic_action_previous_item.png => /project/bin/res/drawable-xxhdpi/ic_action_previous_item.png
        [crunch] (processed image to cache entry /project/bin/res/drawable-xxhdpi/ic_action_previous_item.png: 0% size of source)
        [crunch] Processing image to cache: /project/res/drawable-xxhdpi/ic_action_remove.png => /project/bin/res/drawable-xxhdpi/ic_action_remove.png
        [crunch] (processed image to cache entry /project/bin/res/drawable-xxhdpi/ic_action_remove.png: 0% size of source)
        [crunch] Processing image to cache: /project/res/drawable-xxhdpi/launcher_icon.png => /project/bin/res/drawable-xxhdpi/launcher_icon.png
        [crunch] (processed image to cache entry /project/bin/res/drawable-xxhdpi/launcher_icon.png: 63% size of source)
        [crunch] Processing image to cache: /project/res/drawable/icon.png => /project/bin/res/drawable/icon.png
        [crunch] (processed image to cache entry /project/bin/res/drawable/icon.png: 0% size of source)
        [crunch] Processing image to cache: /project/res/drawable/launcher_icon.png => /project/bin/res/drawable/launcher_icon.png
        [crunch] (processed image to cache entry /project/bin/res/drawable/launcher_icon.png: 0% size of source)
        [crunch] Processing image to cache: /project/res/drawable/share_via_barcode.png => /project/bin/res/drawable/share_via_barcode.png
        [crunch] (processed image to cache entry /project/bin/res/drawable/share_via_barcode.png: 0% size of source)
        [crunch] Processing image to cache: /project/res/drawable/shopper_icon.png => /project/bin/res/drawable/shopper_icon.png
        [crunch] (processed image to cache entry /project/bin/res/drawable/shopper_icon.png: 0% size of source)
        [crunch] Crunched 24 PNG files to update cache
      -package-resources:
        [aapt] Creating full resource package...
        [aapt] (skipping dir '_notes' due to ANDROID_AAPT_IGNORE pattern '_*')
        [aapt] Warning: AndroidManifest.xml already defines debuggable (in http://schemas.android.com/apk/res/android); using existing value in manifest.
      -package:
      [apkbuilder] Current build type is different than previous build: forced apkbuilder run.
      [apkbuilder] Creating GEPLAN-debug-unaligned.apk and signing it with a debug key...
      -post-package:
      -do-debug:
       [zipalign] Running zip align on final apk...
        [echo] Debug Package: /project/bin/GEPLAN-debug.apk
      [propertyfile] Creating new property file: /project/bin/build.prop
      [propertyfile] Updating property file: /project/bin/build.prop
      -post-build:
      debug:
      BUILD SUCCESSFUL
      Total time: 23 seconds
