13 Replies Latest reply on Nov 25, 2016 6:47 AM by vinny38
    Default settings for lists
    vinny38 Level 4
      Hi
      I was wandering if there is a way to modify the default settings of bulleted lists.
      I find the 0.25" (6.35 mm) default indent way too large.
      Of course, using paragraph style is the pro way, but unfortunately, the indesign files are shared and modified by several users, who are not designers.
      So they usually skip the paragraph styles and use directly the paragraph list icon.
      So, basically there are two questions here really:
      1- is there a way to modify the default indents of a specific document?
      2- is there a way to modify the default indents of the sofware itself?
      Thanks in advance
      [windows 7 / INDD CS6]
        • 1. Re: Default settings for lists
          tpk1982 Level 4
          Hi..
          The simplest way is using find and replace.. find the bullets and in the change column give the indent values like below
          HTH
          • 2. Re: Default settings for lists
            tpk1982 Level 4
            I used indent value zero for example
            • 3. Re: Default settings for lists
              vinny38 Level 4
              Thanks, but... that doesn't answer the question really
              I'm a confirmed INDD user and know how to set up indents within a doc.
              What I'd like to do is changing the default settings... Maybe it's just not possible ^^
              Thanks anyway!
              • 4. Re: Default settings for lists
                tpk1982 Level 4
                It may not be direct answer for question but i give the possible way
                • 5. Re: Default settings for lists
                  Most application level default settings can be set by closing all documents and making the desired changes. So in the case of Bullets and Numbering, close all documents and edit Bullets and Numbering  for whatever Paragraph Style you have set as the default—if you haven't built any custom styles it would be the [Basic Paragraph] style—and restart ID.
                  • 6. Re: Default settings for lists
                    BobLevine MVP & Adobe Community Professional
                    Perhaps those other users should be using InCopy, not InDesign.
                    • 7. Re: Default settings for lists
                      vinny38 Level 4
                      Hi Rob
                      Thanks for the answer.
                      Well, the trick would "sort of" work if [Basic Paragraph] is set as bulleted - what I do not want...
                      Besides it would not modify the default 0.25":
                      i.e. Try selecting a paragraph set as bulleted with custom indent, and then click twice on the bullet list icon, paragraph will be set back with default indent (0.25").
                      Anyways, I think my second question is irrelevant, since I won't be able to change preferences to other users. (Just like I won't be able to force them using styles )
                      I'm going to edit* my question and keep the main one:
                      is there a way to modify the 0.25" default indents within a specific document?
                      Thanks anyway
                      *Ah well... I can't edit a question...
                      • 8. Re: Default settings for lists
                        vinny38 Level 4
                        Hi Bob
                        unfortunately, InCopy wasn't part of the Suite (cs6) bought by the company.
                        Updating to CC won't happen either...
                        However, suggestion is helpful, I might transfer it to IT service. I see many cases where InCopy would be useful in the workflow...
                        (Huh... can't find anymore CS6 products on Adobe site, but I'll keep searching...)
                        • 9. Re: Default settings for lists
                          When you choose Bullets and Numbering and set the List Type to something other than None the initial Left Indent is set paragraph style's Left indent setting under Indents and Spacing. The application and every document has at least one editable paragraph style [Basic Paragraph], so the starting left indent can be set there for a document when there are no text frames or text selected. If you want the indent to be different for normal text and list text you would have to set up two different styles, but then that's the point of styles.
                          So:
                          With the [Basic Paragraph] style set as above invoking a new text frame's text's Bullets and Numbering would default to this:
                          • 10. Re: Default settings for lists
                            InCopy is $5/month with a one year commitment and includes CS6 and later versions.
                            • 11. Re: Default settings for lists
                              vinny38 Level 4
                              Well, it has to be different: 0 for normal and x/-x for lists.
                              So yes, the right answer is styling. Unfortunately I can't get users to use them properly. This is why I wish I could change the default indent.
                              Here's the illustration of what is happening all the time... Just before typical phone call "Hey, damn graphic designer, why does my list look crappy?"
                              • 12. Re: Default settings for lists
                                It's not going to happen—lists use the paragraph's indent setting. I would assume you will run into other problems if the user can't handle something as basic as applying a style, so Bob's InCopy suggestion is the best way to handle workflows where editors don't know how to use ID.
                                • 13. Re: Default settings for lists
                                  vinny38 Level 4
                                  Right, this is what I was afraid of.
                                  InCopy is definitely a great suggestion.
                                  Thanks all for your time
                                  You cannot imagine...
