We have a plugin developed for Illustrator CS5. We want to upgrade the plugin to be compatible with Illustrator CC 2015.
There were lot of changes and Adobe deprecated lot of existing libraries and introduces new things. To start with, we tried to build freegrid plugin from sample code from SDK. The freegrid.aip file got generated when built using VS2013. We copied this file to Illustrator plugin folder and started the Illustrator. It is giving error loading plugin message.
We tried to change build properties to change it to 64 bit but still the same problem.
We are really stuck here.
Appreciate your response on this.
Thank You,
Aniket
