Hi ,
I have a report in Crystal Reports 2011. It's a fairly simple report with normal text (Arial and Tahoma) in various columns
I have exported crystal report to pdf and generated pdf .
I tried to convert generated pdf to fillable pdf by using Adobe Acrobat XI Pro, i am getting Bad Error;Error in Processing Fonts.<un supported type2 Font>[1].
I tried to change my crystal report font to True type font still i am facing same issue.
Could you please help to resolve this issue, i am not able to convert fillable pdf from crystal report pdf's.
Suresh
Alas, not uncommon for a PDF coming form Crystal Reports.
Using Acrobat Pro you may be able to manually build the form.
What you are seeing is the result of a corrupt PDF file. Crystal Reports is one of the biggest offenders when it comes to corrupt PDF files. Complain to their customer support and hope that they will eventually fix their problems - but don't hold your breath, you are not the first one with this complaint.
