• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Turn off Bounding box
Community Beginner ,
Nov 25, 2016 Nov 25, 2016
How do I turn off the bounding box in Illustrator CC (2017) and have it stay off until I call for it again?
Views
6.0K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe
Community Expert ,
To turn the bounding box off for all documents. launch Illustrator but don't open any files. Then choose View > Hide Bounding Box. You will see the handy keyboard shortcut next to the command which will make it fast and easy for you to turn the bounding box on and off at will.
Votes
Translate
Translate
Report
Report
Community Expert ,
Nov 26, 2016 Nov 26, 2016
That sounds more like the way you would do it in InDesign.
Illustrator remembers the setting, if you turn it off (with or without document open), it will stay off.
I guess the question is related to the behaviour of selecting a typeface in CC 2017. Even if the Bounding Box is off, changing font will turn it on.
Votes
Translate
Translate
Report
Report
Is there no way to stop the bounding box from coming on when you change a typeface?
Votes
Translate
Translate
Report
Report
Community Expert ,
Not in the current 2017 version, it looks like a bug.
It may be a good idea to mention it here:
Feature Request/Bug Report Form
Votes
Translate
Translate
Report
Report
Thank you, that is the problem. I'll write to Adobe.
Votes
Translate
Translate
Report
Report
Nov 27, 2016 Nov 27, 2016
The link you gave me: Feature Request/Bug Report Form  only seems to be related to Acrobat do you have a link to the Illustrator Bug report?
Votes
Translate
Translate
Report
Report
Community Expert ,
Just select a different product from the list.
Votes
Translate
Translate
Report
Report
Here's the list. Where's Illustrator?
Votes
Translate
Translate
Report
Report
Community Expert ,
This link should get you there. Let us know.
Illustrator Feature Request/Bug Report Form
Votes
Translate
Translate
Report
Report
Community Expert ,
LATEST
I see what the problem is.
The scrollbar to get to other products disappears instantly.
You either have to use a scrollwheel or use another scrollfuntion (like a two finger gesture on a trackpad) to get to the other applications.
I see Barbara's link on the main Illustrator forum page, but also in Illustrator's Help menu. Help > Submit Bug/feature Request...
Votes
Translate
Translate
Report
Report
Community Expert ,
Normally this would give you a choice.
So this means all bugs are solved (except for Acrobat) or the form is broken.
I suspect the last.
Barbara's link seems to work (although I've never seen that one).
Votes
Translate
Translate
Report
Report
Community Expert ,
With bounding box turned off, if you have area type what looks like a bounding box will still show. However, Illustrator considers it an "Edge", not a "Bounding Box". To hide the edge, choose View > Show/Hide Edges.
Votes
Translate
Translate
Report
Report
Community Expert ,
But in CC 2017 the Bounding Box will reappear when you change the font for your selected text.
Votes
Translate
Translate
Report
Report
Community Expert ,
Sounds like you've pinpointed a bug in 2017. I'm using Illustrator 2016.3.1 and the problem does not occur when changing font.
Votes
Translate
Translate
Report
Report
Community Expert ,
That's right Barbara, it happens only in the latest version; 21.0.0
Votes
Translate
Translate
Report
Report
Community Expert ,
You're right, Ton. In Illustrator the setting sticks with or without document open. I'm also an InDesign user.
Votes
Translate
Translate
Report
Report
