4 Replies Latest reply on Dec 10, 2008 3:54 PM by pedro_poc
    Is this a Number?
    Level 7
      Dear All,
      I have created a couple of functions. The PickRandomBox function selects the
      first item from a radomised array. The second function takes this value
      along with a basic if statement to return a string. The problem seems to be
      that the second function does not see the input value, boxcode, as a Number.
      A couple of trace statements show me that the array returns an entry but the
      if statements doesn't see the value as a number that it can evaluate. I have
      tried using the int function to convert the first value from the array but
      it always returns a 0.
      I am totally confused. It seems as if an element of an array is not a
      Number.
      Please put me out of my misery.
      Alastair MacFarlane
      arr: 3,18,27,32,5,9,37,1,12,21
      The colour number is: 3
      MORAY FIRTH COAST - (Unsure - Box 3)
      function PickRandomBox(arr:Array){
      arr.randomize();
      trace("arr: " + arr);
      trace(_root.boxnames[arr[0]] + " - " + BoxCodeDescr(arr[0]));
      function BoxCodeDescr(boxcode:Number) {
      trace("The colour number is: " + boxcode);
      //boxcode=27;
      if (boxcode == 1 || boxcode == 3) {
      return "(Brown - Box " + boxcode + ")";
      break;
      } else if (boxcode == 5 || boxcode == 15 || boxcode == 25 || boxcode == 35)
      return "(Airport - Box " + boxcode + ")";
      break;
      } else {
      return "(Unsure - Box " + boxcode + ")";
      break;
        • 1. Re: Is this a Number?
          How is your array declared in the code? I'm assuming what you show in the first line isn't it.
          What is the randomize() function? It's a new one to me if it's a valid array method.
          You don't need to have the break;'s, they are primarily for stopping a loop, which you don't appear to be using.
          • 2. Re: Is this a Number?
            evanton
            Thanks NedWebs,
            I have declared the array as below. Nebwebs, I would say don't spend too
            long on it. I have a workaround that will do but the inquisitive side of me
            wants to know why it does not work. Thanks again very much for your help.
            All the relevant code is here, I think! Alastair
            On Frame1, Layer1
            boxnames = new Array("GO", "MORAY FIRTH COAST", "Community Chest", ...)
            boxmodes = new Array(0, 2, 0, 2, 0, 0, 3, 3, 3, ...) -// where the values 0,
            1, 2 ,3 all mean different things
            On Frame1, Layer2
            function PickRandomUserBox(){
            var myArray:Array = Array();
            len = _root.boxmodes.length;
            for (var i = 0; i<len; i++) {
            if (_root.boxmodes == 2) {
            myArray.push(
            ); // Creates an array of all the box nos with a 2
            return _root.PickRandomBox(myArray);
            break;
            arr.randomize();
            // Returns the first box no with the array[0]
            trace("arr: " + arr); //==========> arr: 3,18,27,32,5,9,37,1,12,21
            trace(_root.boxnames[arr[0]] + " - " + BoxCodeDescr(arr[0])); //==========>
            // This Random Array was created with the help of yourself and Rothrock
            Array.prototype.randomize = function ()
            var __mon2 = this.length;
            if (__mon2 != 0)
            while (--__mon2)
            var __mon3 = Math.floor(Math.random() * (__mon2 + 1));
            var __mon5 = this[__mon2];
            var __mon4 = this[__mon3];
            this[__mon2] = __mon4;
            this[__mon3] = __mon5;
            return this;
            ASSetPropFlags(Array.prototype,["randomize"],1,1);
            //boxcode=27;
            break;
            break;
            } else {
            break;
            • 3. Re: Is this a Number?
              Do you get a valid number out of the trace:
              in the BoxCodeDescr function?
              If not, my suspicions fall on the randomize end of things. I am not familiar with the prototype aspect of things, so I can't offer any help there. But one thing that I question is that the randomize function returns a value, so from my old world experience I would expect to see something of the nature of:
              arr = arr.randomize();
              • 4. Re: Is this a Number?
                pedro_poc
                Did you try parseInt() instead of int()?
                just a quick guess, it might not work.
